Re: 440 block cracks in lifter valley
[Re: Quicksilver440]
#1974435
12/22/15 11:51 AM
12/22/15 11:51 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
Yep, it froze. They'll crack like that on the outside of the block b/t the core plugs too. It could be stitch pinned and saved, but not worth it in my opinion...unless it was the matching numbers block or something.
[Re: an8sec70cuda]
#1974468
12/22/15 12:27 PM
12/22/15 12:27 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I used stop leak on a old Imperial that was like that.. it lasted till I sold it.. I had to change the oil twice then it was fine... I wouldnt race a block like that
#1974667
12/22/15 05:33 PM
12/22/15 05:33 PM
Posts: 43,193 Bend,OR USA
Cab_Burge
Definetily a freeze crack, how is the rest of the block? Usually when you see one there are others I had a 426 street wedge block that was crack on both sides, insides and out as well as having a casting flaw on the bottom of one cylinder that had been leaking into the crankcase The customer wanted it fixed so he could use it in his 1965 Satelite 426 W car I would check with your local machine shops and see what they will charge you to stitch plug repair it The shop I use was so much a inch, it is not a welding process. They drill the crack and insert a twist off plug and then drill out half of that plug and insert another twist and so on until they go past the entire length of the crack It flat works well, no leaks and no problems
#1974724
12/22/15 07:45 PM
12/22/15 07:45 PM
Posts: 4,457 Washington
madscientist
Washington
Just use Hard Block and fill it up until it just covers the crack. Then run it.
[Re: madscientist]
#1974728
12/22/15 08:03 PM
12/22/15 08:03 PM
Cab_Burge
Just use Hard Block and fill it up until it just covers the crack. Then run it. I tried that on a old top fuel Mopar cast iron block, most block filler are porous and lets the water flow right through it If Hard Block is the plastic epoxy filler it may not let water through, maybe it will I ended buying some block sealer from Goodson that you had to put in the block under pressure for 10 to 20 minutes and then empty it, it was resuable and have the block or heads cook in a oven for a set time at a high temps, under 400 F if my memory is halfway near correct That was twenty years or more ago that block sealer flat worked, that block leaked like a siv before, not so after that sealer was done
#1974801
12/22/15 10:17 PM
12/22/15 10:17 PM
Posts: 4,206 New York
polyspheric
New York
I'd be nervous not knowing what else moved when the crack happened - like from the jacket to the outside of a cylinder wall.
I tend to make decisions that leave me comfortable!
Boffin Emeritus
