Hemi K Member ??? #1973914
12/21/15 05:10 PM
12/21/15 05:10 PM
SO CAL
BB70DUSTER Offline OP
SO CAL
I have a Hemi K member that came out of a 65 Coronet, Will this fit in my 71 Cuda? I know the steering shaft angle may be off, and Im OK with that... Anyone know what if any difference there would be in a 65 B body Hemi K member VS a 66 and later one? For all I know it may be a 66 and later one that was put in the car for the swap... THANKS!!!
Re: Hemi K Member ??? [Re: BB70DUSTER] #1973921
12/21/15 05:20 PM
12/21/15 05:20 PM
Strathroy, Ontario
BS27R1B Offline
BS27R1B  Offline
Strathroy, Ontario
The drag link is different as is the skid plate and the driver side mount.
Not sure the older b-body k-member will bolt in or bolt in and locate the engine in the right location in an e-body
'.. it was long ago and it was far away, and it was so much better than it is today..'
Jim Steinman
Re: Hemi K Member ??? [Re: BS27R1B] #1973936
12/21/15 05:34 PM
12/21/15 05:34 PM
SO CAL
SO CAL
I know the later B body K frame bolts in a early B, but it changes engine location... Really not sure if the Hemi one changes... All the pics I find of Later B body ones look identical to what I have...
Re: Hemi K Member ??? [Re: BB70DUSTER] #1974003
12/21/15 07:22 PM
12/21/15 07:22 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I need a 65 Hemi K member if you want to dispose of it.
Rick 501-519-7425
2011 Drag Pak Challenger
Re: Hemi K Member ??? [Re: BB70DUSTER] #1974047
12/21/15 08:52 PM
12/21/15 08:52 PM
SO CAL
SO CAL
Im hoping it will work, but may end up available if not...
Anyone else know if it will work?
Re: Hemi K Member ??? [Re: BB70DUSTER] #1974065
12/21/15 09:29 PM
12/21/15 09:29 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Yes, the engine sits different in a E body compared to the older B bodies.
Re: Hemi K Member ??? [Re: BB70DUSTER] #1974524
12/22/15 01:58 PM
12/22/15 01:58 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Why not work a trade for the right one you need?
Re: Hemi K Member ??? [Re: JohnRR] #1974657
12/22/15 05:15 PM
12/22/15 05:15 PM
SO CAL
SO CAL
Im not opposed to that...
Re: Hemi K Member ??? [Re: 71birdJ68] #1974658
12/22/15 05:15 PM
12/22/15 05:15 PM
SO CAL
SO CAL
I know the big block does, but do you know for sure that a Hemi did also?
Re: Hemi K Member ??? [Re: BB70DUSTER] #1974659
12/22/15 05:16 PM
12/22/15 05:16 PM
SO CAL
SO CAL
The K member out of the 65 looks identical to a later B body one... Is the difference (if any) noticeable?
Re: Hemi K Member ??? [Re: BB70DUSTER] #1974707
12/22/15 07:18 PM
12/22/15 07:18 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
A true 65 Hemi k frame does not have any skid plate if my memory is correct. A 66 Hemi k frame will. I sold my 65 Hemi car so I can't look to see.
Re: Hemi K Member ??? [Re: fastmark] #1974756
12/22/15 09:02 PM
12/22/15 09:02 PM
SO CAL
SO CAL
I believe the one in my 65 was made by Phil Newcomb (Hemispherical Productions, or something like that...) But does not have a skid plate, has sway bar holes in the front...
Re: Hemi K Member ??? [Re: BB70DUSTER] #1975619
12/24/15 01:03 PM
12/24/15 01:03 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
No Street Hemi in '65 so it's probably a '66 or later that was swapped in.
Re: Hemi K Member ??? [Re: BB70DUSTER] #1975751
12/24/15 04:50 PM
12/24/15 04:50 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Yes, a Hemi does also. Remember they all used the same hoods and scoops and other stuff that didn't change between engines.
Re: Hemi K Member ??? [Re: 71birdJ68] #1979119
12/30/15 01:50 AM
12/30/15 01:50 AM
San Francisco Ca
SCATPK Offline
SCATPK  Offline
San Francisco Ca
I know for a fact that a later 66- up hemi k frame in a 64/65 b-body moves the engine back about 3/4". Had this problem with a 64 when purchased and the cross ram touched the firewall. Installed a 64 hemi k frame and engine moved forward into the correct position.
