Re: Run hollow body rollers or not
[Re: drag440]
#197321
01/18/09 08:47 PM
01/18/09 08:47 PM
Thumperdart
State of confusion
If the oil band is above the lifter bore at full lift, you`ll have low/no oil pressure.
[Re: Thumperdart]
#197322
01/18/09 11:23 PM
01/18/09 11:23 PM
Posts: 672 Keysville, VA
drag440
mopar addict
mopar addict
Keysville, VA
If the oil band is above the lifter bore at full lift, you`ll hae low/no oil pressure.
Looks like you should be able to see that when you are putting a engine together.
[Re: drag440]
#197324
01/19/09 07:30 PM
01/19/09 07:30 PM
Thumperdart
State of confusion
You would definately see it when you drop em in and turn it over.
[Re: drag440]
#197326
01/20/09 11:25 AM
01/20/09 11:25 AM
Posts: 871 WA 98043
thecarfarmer
WA 98043
I'm assembling (slowly) a '68-9 383 block with a set of Herbert rollers.
They have the band around 'em.
With the roller on the base circle of the cam, the area of the lifter body that's notched out for the roller is visible under the lifter bores, but that's about it; shouldn't be able to lose oil pressure there.
With the roller going over the nose of the lobe (should be about .394" lobe lift - advertised .591" w/ 1.5 rockers), there's about .150-.200" more the lifter can come up before it exposes the band out of the top of the lifter bore.
Don't know what brand you want to run, but hope this helps.
-bill
Seduce the attractive, and charm the rest.
489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
[Re: drag440]
#197327
01/20/09 02:54 PM
01/20/09 02:54 PM
Posts: 43,309 Bend,OR USA
Cab_Burge
OK, whats the real deal on the hollow body rollers. Can you run them in a stock non bushed block or not? Are 400 blocks the only ones having problems or do 440's have problems also? Is it just big rollers? Is it just certain brands? How do you know if you have a problem? Can you prime the oil system with a drill and have someone else turn the engine at the same time and see it? Can you just see it by eye? Do they leak at the bottom or top? I have a set that I would like to use in a 440 with a .700 roller and the left side galley blocked, but I'm gun shy
first of all I think that all solid roller lifters use a hollow body, at least all of the ones I seen, second as far as priming the engine and seeing the leaks you can install a mechanical oil gauge on the motor and prime the motor while you turn it over slowly, when the guilty lifters, if any leak, reach the top of there travel the oil pressure will drop I have ran a lot of different brand, sizes and shapes of solid roller lifters in all the big block blocks, early, late, hemi, B and RB. One Hemi block leak on the drivers side on a big Crane (.800+ lift at the retainers, 292 and 296 @ .050))roller cam. As far as where they leak they leak at peak lift, try yours first of course and use them if they don't loose oil pressure on the stand. There are several cures, the easyest is swapping lifters to a brand that have the long skirt on the oil galley side to block the oil galley off at high lift, another is to use a small base circle cam, not my favorite method due to spring pressures and cam deflection at high lift and high rpms The best and most expensive way is to bush the block BTW, my 400 block street motor had the Mopar brand skirted solid roller lifters in it and they work great, .720 net lift at the retainers
