Re: can someone help identify my holley carb?
[Re: 1_WILD_RT]
#197297
01/18/09 10:50 PM
01/18/09 10:50 PM
Posts: 3,407 S.E. Florida, USA
rrunner
S.E. Florida, USA
Think you will find it's not the base gasket leaking, but the throttle shaft. The list # will tell what you have, my guess is a 3310 = 750 vacuum secondary
rruner nails it...
"Thank You, Thank You, Thank You Very Much"
[Re: AHall]
#197299
01/19/09 12:18 PM
01/19/09 12:18 PM
RapidRobert
you might pull the carb & see if you can ID where it's leaking from & replace that gasket. from the pic it might be the AP gasket. I have an extra one you can have. Be alot cheaper than purchasing a whole new carb & it'll give you the satisfaction of solving the problem
[Re: RapidRobert]
#197300
01/19/09 05:11 PM
01/19/09 05:11 PM
Posts: 423 DFW Texas
AHall
DFW Texas
you are the man! Can I get your contact info?
