Re: New AN Hose - Stainless or ?
[Re: ahy]
#1972881
12/19/15 08:37 PM
12/19/15 08:37 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
Aeroquip teflon line. Won't rot. Much smaller OD. But you will need all new hose ends.
The downside is really cost. Super easy to install.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
[Re: ahy]
#1972995
12/19/15 11:49 PM
12/19/15 11:49 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I use parker Teflon, I have real milspec ends and they cost about $150.00 for the 45* ends each, the parker JIC industrial ends are around $20 each for straight. I think the aeroquip number is 666....it is. See the attached link for more information. Tim https://www.aircraftspruce.com/catalog/pdf/aeroquip666.pdf
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: ahy]
#1973309
12/20/15 04:14 PM
12/20/15 04:14 PM
Posts: 43,193 Bend,OR USA
Cab_Burge
I use soft anadized aluminum lines with AN fittings from the pump to the fuel regulator and TFE soft lines every else You can use steel lines also If you want all flex lines then I would use the Teflon lined hose in the size you want to use.
[Re: ahy]
#1973436
12/20/15 08:25 PM
12/20/15 08:25 PM
astjp2
Utah and Alaska
I did find a deal for 1/2" .035 wall stainless tubing, its a [censored] to bend but for $8.00 per 20' stick, I could not turn it down. I also got 3/8" for $12 I didn't turn it down either....
