Fast bleed hyd lifters #1972547
12/19/15 05:02 AM
12/19/15 05:02 AM
NewZealand
downunder Offline OP
NewZealand
Looking for opinions on using a fast bleed anti-pump lifter in a 440 with a xe285hl cam. Do they work in regard to increasing vacuum, with the fast bleed, are they more prone to lifter collapse, thanks.
Re: Fast bleed hyd lifters [Re: downunder] #1972550
12/19/15 05:36 AM
12/19/15 05:36 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
The Rhodes I had in my 440 charger 30yo were quite noisy, sounded like junk, Not sure what they are like now in modern times or if the fast bleeds are more for hi rpm anti pump up as opposed to Rhodes which were more for taming a big cam down low.
Re: Fast bleed hyd lifters [Re: ademon] #1972551
12/19/15 06:12 AM
12/19/15 06:12 AM
NewZealand
NewZealand
I have looked on Hughes site and they list one, part # HUG 5003, Hylift Johnson. These are the ones I was looking at. They have a engine test on their site which uses these, seems to hold on well.
