Re: Spray Undercoating Touch-Up - What to Use?
[Re: B5Cuda440-6]
#1972490
12/19/15 01:48 AM
12/19/15 01:48 AM
Posts: 4,787 Star Idaho
67vertman
Star Idaho
I used a rubberized undercoating.....and pulsed the trigger, so it came out more with a textured look. from a foot away it is hard to tell its not factory.
My Monster are real!
Living within your means makes life pretty easy.
[Re: B5Cuda440-6]
#1972919
12/19/15 09:39 PM
12/19/15 09:39 PM
Posts: 7,196 Harrisburg, Pa.
screamindriver
Harrisburg, Pa.
Some of the new {aerosol}formulas don't like being sprayed on too thick..You might get it built up to match the surrounding areas only to find it cracked while drying or shrank and needs another coat anyhow...Take your time and don't rush it if you go that route... The old style undercoating had it's own spray gun that screwed on top of the container and splattered up everything including the floor..The discharge hole in that gun was almost as big as the air hose diameter itself...So you won't be running any thick undercoating through an HVLP paint gun no matter who's formula it is... As stated cover everything including the floor it's going everywhere even if you use an aerosol can type product... I wear a disposable suit and old shoes.. there's no gracefull way to do it !!
[Re: screamindriver]
#1973174
12/20/15 11:47 AM
12/20/15 11:47 AM
Posts: 19,521 north of coder
moparx
Some of the new {aerosol}formulas don't like being sprayed on too thick..You might get it built up to match the surrounding areas only to find it cracked while drying or shrank and needs another coat anyhow...Take your time and don't rush it if you go that route... The old style undercoating had it's own spray gun that screwed on top of the container and splattered up everything including the floor..The discharge hole in that gun was almost as big as the air hose diameter itself...So you won't be running any thick undercoating through an HVLP paint gun no matter who's formula it is... As stated cover everything including the floor it's going everywhere even if you use an aerosol can type product... I wear a disposable suit and old shoes.. there's no gracefull way to do it !! i believe it was called a "shutz" gun. hth
[Re: B5Cuda440-6]
#1973751
12/21/15 12:14 PM
12/21/15 12:14 PM
Posts: 13,604 md
mopars4ever
md
[Re: B5Cuda440-6]
#1976458
12/26/15 03:30 AM
12/26/15 03:30 AM
Posts: 8,399 Highland, MI.
Sunroofcuda
Highland, MI.
I used the Shutz coating years ago & it still did not go on like the factory undercoating. The OE stuff was SUPER thick & very rough textured. Still not sure how I'm going to re-apply the heavy build stuff to the quarters inside the trunk of my AAR. I'll have to talk with Frank Badalson to get some advice from him before I try.
