Clutch ? 78 d100 3spd #1971076
12/16/15 09:24 PM
12/16/15 09:24 PM
Atlanta, GA
mgoblue9798 Offline OP
Atlanta, GA
I recently acquired a 78 d100. It has a 318 w/ 3spd on the tree. It needs a clutch, but two different sizes show for this app on Rockauto. Is there a way to tell what size clutch is in the truck without taking it apart? I really would like to get the entire job done in a day if possible and not have it sitting waiting on parts. Thanks.
Re: Clutch ? 78 d100 3spd [Re: mgoblue9798] #1971126
12/16/15 10:52 PM
12/16/15 10:52 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
do you know what model trans it is?
Re: Clutch ? 78 d100 3spd [Re: Quicksilver440] #1971127
12/16/15 10:55 PM
12/16/15 10:55 PM
Atlanta, GA
Atlanta, GA
I don't, all I know is that it is a manual 3 spd trans.
Re: Clutch ? 78 d100 3spd [Re: mgoblue9798] #1971279
12/17/15 03:00 AM
12/17/15 03:00 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I suspect the differences is in the clutch diameter. Are your choices 9" and 10 1/2"? You should be able to pull the inspection cover on the bottom of the bell and get a rough measurement of the outside edge of the disc that should get you close enough to be able to determine which clutch is in there. Gene
Re: Clutch ? 78 d100 3spd [Re: poorboy] #1971479
12/17/15 03:42 PM
12/17/15 03:42 PM
Atlanta, GA
Atlanta, GA
Thank you I will give it a try. Clutch is either 10.5 or 11 on this one.
Re: Clutch ? 78 d100 3spd [Re: mgoblue9798] #1971500
12/17/15 04:18 PM
12/17/15 04:18 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
Call a dealer, give them the serial number, see if they can tell you what it is.
Re: Clutch ? 78 d100 3spd [Re: mgoblue9798] #1971566
12/17/15 06:29 PM
12/17/15 06:29 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I'd bet on the 10 1/2", but measure it anyway. Remember the size is determined by the outside edge of the disc, not where the cover bolts to the flywheel.
I think the dealers around here threw out everything concerning anything older then 1994 out when the 1994 trucks came out. When you bring up anything concerning something older then 94, they get that deer in the headlights look and start talking funny. Gene
Re: Clutch ? 78 d100 3spd [Re: mgoblue9798] #1972471
12/19/15 01:27 AM
12/19/15 01:27 AM
woodcrest, CA
magnum440d100 Offline
woodcrest, CA
My 72 3 on the tree was the 11". Went to a833od and its 10.5.
Just my 2cents.
Re: Clutch ? 78 d100 3spd [Re: mgoblue9798] #1972879
12/19/15 08:33 PM
12/19/15 08:33 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
It's an A230 but it could still be 10.5" or 11.0" clutch.
