Did I put my manual steering box back together wrong? #1971054
12/16/15 08:52 PM
12/16/15 08:52 PM
Virginia
HemiStan Offline OP
HemiStan  Offline OP
Virginia
My steering box seems to be 4 1/2 turns lock to lock. (20:1 ratio?). Anyways, when I turn it to center (2 1/4 turns), the master spline on the steering box is not at the 12 o'clock position. It actually seems to be at the 9 o'clock position. Did I put this box back together incorrectly or is it normal?
Thanks.
Stan
Re: Did I put my manual steering box back together wrong? [Re: HemiStan] #1971138
12/16/15 11:08 PM
12/16/15 11:08 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Which master spline? The one on the input shaft or the one on the output?
Re: Did I put my manual steering box back together wrong? [Re: Stanton] #1971179
12/16/15 11:57 PM
12/16/15 11:57 PM
Virginia
HemiStan Offline OP
HemiStan  Offline OP
Virginia
Stanton,
The master spline on the input (the one that the steering column/shaft connects to).
Stan
Re: Did I put my manual steering box back together wrong? [Re: HemiStan] #1971183
12/17/15 12:01 AM
12/17/15 12:01 AM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Yes...
The 'coupler' side should be equally divided, lock to lock...
Re: Did I put my manual steering box back together wrong? [Re: HemiStan] #1971184
12/17/15 12:03 AM
12/17/15 12:03 AM
You have the play taken out & are exactly halfway. I like a hint of play in the col for the final adjustment but for this I'd get it just to no play to definitely confirm you are halfway.
Re: Did I put my manual steering box back together wrong? [Re: RSNOMO] #1971186
12/17/15 12:05 AM
12/17/15 12:05 AM
Virginia
HemiStan Offline OP
HemiStan  Offline OP
Virginia
RS23U1G
Got it. I will take it apart this weekend and have a look. I rebuilt this box about 4 years ago and it has been siting on my shelf since then. Time to find out what I did wrong.
RapidRobert,
I haven't got the column in yet. Things just didn't seem right.
Thanks!
Stan
Re: Did I put my manual steering box back together wrong? [Re: HemiStan] #1971189
12/17/15 12:07 AM
12/17/15 12:07 AM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
They're pretty straightforward...
Got a FSM???
Describes the entire rebuild procedure...
Re: Did I put my manual steering box back together wrong? [Re: RSNOMO] #1971190
12/17/15 12:08 AM
12/17/15 12:08 AM
Virginia
HemiStan Offline OP
HemiStan  Offline OP
Virginia
RS23U1G,
I definitely have a FSM. Very worn and tattered. I will pull everything back apart and have a look.
Stan
Re: Did I put my manual steering box back together wrong? [Re: HemiStan] #1971233
12/17/15 01:24 AM
12/17/15 01:24 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
All you have to do to correct it is pull the top cover (3 bolts). Pull out the cross shaft, center the unput shaft, and drop the cross shaft back in centered. You shouldn't even need to do any adjusting, just torque the 3 bolts back down. 10 minutes !!
Re: Did I put my manual steering box back together wrong? [Re: Stanton] #1971339
12/17/15 09:29 AM
12/17/15 09:29 AM
Virginia
HemiStan Offline OP
HemiStan  Offline OP
Virginia
Stanton,
Very cool. Thanks!
Stan
