Re: using cometics with different thickness one side vs other
[Re: mopar dave]
#1969533
12/14/15 04:41 PM
12/14/15 04:41 PM
Posts: 4,457 Washington
madscientist
Washington
Picking the fly poop out of the pepper. You need to lose 1.5 cc's or gain 1.5 cc's.
Can't you make one head smaller by milling or one head bigger by a little chamber massaging?
[Re: mopar dave]
#1969579
12/14/15 05:21 PM
12/14/15 05:21 PM
madscientist
Washington
Now that I think about it, you could put the smaller head on the even bank and let it go. It won't even know it.
I had engines that ran very well come into the shop with 2 different heads on them. this was an issue in the late 90's early 00's with Canfields from jegs. The order puller would pick the heads up and not check the boxes. guys would bolt them on and run them.
We obviously fixed them, but when you tell someone their heads don't match they think something is up. But I have seen the mistake many times.
[Re: mopar dave]
#1969587
12/14/15 05:36 PM
12/14/15 05:36 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If its just the chambers and not the height of the head I'd let it fly.. all you would be doing by cutting it or different gaskets is messing up the push rod lengths.. just make sure its just in the chambers.. if you REALLY want it balanced then touch up the chambers on the one head
[Re: mopar dave]
#1969638
12/14/15 07:07 PM
12/14/15 07:07 PM
MR_P_BODY
Take them back to who did the heads.. have them open up the one head(chambers).. I guess that place doesnt measure the chambers when they do heads
[Re: MR_P_BODY]
#1969683
12/14/15 08:29 PM
12/14/15 08:29 PM
dartman366
Mt. Vernon, Ohio
after seeing how far off my heads were and spending a bunch of money to fix them and not seeing one bit of difference in performance i'm not so sure I would worry about it, and mine were 7 cc's different from big to little and ended up being one compression point different high to low.
[Re: mopar dave]
#1970244
12/15/15 04:44 PM
12/15/15 04:44 PM
madscientist
Washington
ordered cometics today. talked to Bob@FBO about using different size head gasket per side and he tells me he has done that very same thing 20+ times on engines he has built over the yrs. didn't think it was an issue. so I ordered .030 and .036 gaskets. we are only talking .006" difference per side. $155/pair til first on yr. I've done it before, but we did before and after dyno pulls. We found a big fat zero. We did put the big chambers on the #2 side. I was actually thinking of swapping the heads from side to side to dyno but said screw it. IIRC it was about 650 HP and it was a Dorf (Ford spelled kinda backwards...like drof but I like Dorf better). FWIW I enjoy picking the pepper out of the fly poop as long as I'm not paying for it.
[Re: dirtybee]
#1970360
12/15/15 07:51 PM
12/15/15 07:51 PM
dartman366
Mt. Vernon, Ohio
what about in my case where the machine shop took 16 thou too much off the passenger side when they were asked to zero deck the block? everything else checks out fine but my flat tops are 16 thou out of the hole on the one side. I would say they owe you a new block, I would be pizzed.
[Re: dirtybee]
#1970414
12/15/15 09:03 PM
12/15/15 09:03 PM
madscientist
Washington
what about in my case where the machine shop took 16 thou too much off the passenger side when they were asked to zero deck the block? everything else checks out fine but my flat tops are 16 thou out of the hole on the one side. Cut the block so both sides are the same. Use thicker gaskets or put the pistons in a piston vise and machine .016 off the top. Since it's a FT you could do it in a lathe too.
[Re: dirtybee]
#1970495
12/15/15 11:00 PM
12/15/15 11:00 PM
Posts: 43,215 Bend,OR USA
Cab_Burge
