Which manual trans to buy?
#1968799
12/13/15 04:16 AM
12/13/15 04:16 AM
Posts: 48 the Netherlands
dutchrunner
the Netherlands
At this time my 69RR has a John Cope CRT-4(VMRVB). Am very happy with it sofar.
For next winter I am planning on going manual trans.
Problem now is which do I buy.
Hemi has 750hp and about 600ft-lbs (pro-charger upgrade in future).
Really like to have an overdrive and good street use (downshift). Also like to have Vertical gate shifter.
Called McLeod about their new trans but has 500 ft-lbs limit.
Called G-Force about their GF5R with Vgate shifter but no syncro in this box. Also their Street 6-speed is a great trans but no Vgate shifter. Liberty is also no street trans.
Any tips.
1969 Roadrunner Sox&Martin tribute with 572Hemi and F&B performance Six-Pack XFI2.0 injection.
Re: Which manual trans to buy?
[Re: dutchrunner]
#1968874
12/13/15 12:32 PM
12/13/15 12:32 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
If production ever increased, I would use a Passon 5 speed Hemi box for your application. Your 600 ft-lbs engine torque is only relevant if you are putting all of it to the ground. If you are racing on slicks it might be more critical, but I am guessing that this is a street car since you want a syncro box. I'm still using the same hemi box in my 'Cuda since the mid 1980's and my car has run high 9's. The new motor will push it into the 8's and I'm planning on using the same trans, just different clutch setup.
[image][/image]
[Re: dutchrunner]
#1968931
12/13/15 02:24 PM
12/13/15 02:24 PM
dutchrunner
the Netherlands
Thanks for the info RTSE4ME , but in same Gforce info they state :
Because of the unique engagement system of a clutchless G-Force, the transmission is not suitable for the street and will pop out of gear under deceleration. Since the clutchless G-Force is not a planetary transmission, it doesn't impose the same type of power losses.
[Re: dutchrunner]
#1968961
12/13/15 03:18 PM
12/13/15 03:18 PM
Posts: 43,237 Bend,OR USA
Cab_Burge
Back when the Verti Gate shifters first came out I heard a lot of racers hating them, I tried driving a freinds car for him and I didn't like it either The Long shifters where much better according to the guys that had them Look around and see if you can locate one of them in decent shape that is based on you not driving a car with one of them in it If you have driven one and like them then go for it
[Re: dutchrunner]
#1969027
12/13/15 05:14 PM
12/13/15 05:14 PM
Posts: 4,457 Washington
madscientist
Washington
I don't get how the McLeod can only hold 500 lbs TQ? An 833 hemi box will do way more than that.
Guess I need to see what they made.
[Re: Cab_Burge]
#1969033
12/13/15 05:20 PM
12/13/15 05:20 PM
sgcuda
Back when the Verti Gate shifters first came out I heard a lot of racers hating them, I tried driving a freinds car for him and I didn't like it either The Long shifters where much better according to the guys that had them Look around and see if you can locate one of them in decent shape that is based on you not driving a car with one of them in it If you have driven one and like them then go for it My car is set up with a V-gate. I like V-gates over H pattern shifters. Besides being different, I have seen people (Not me!) pull wrong gears with an H pattern shifter. I have had people drive my car, and no one has ever missed a proper shift. Never had the opportunity to use a Long style.
[image][/image]
[Re: dutchrunner]
#1969035
12/13/15 05:24 PM
12/13/15 05:24 PM
madscientist
Washington
Yup, I used a Vetrigate on the street all through the 1980's. There would be one in my DD if I wanted to cut the crap out of the floor.
[Re: madscientist]
#1969040
12/13/15 05:32 PM
12/13/15 05:32 PM
sgcuda
Guess I need to see what they made. I can't see a 45 year old production transmission holding as much power as a modern day box from McLeod.
[image][/image]
[Re: dutchrunner]
#1969045
12/13/15 05:43 PM
12/13/15 05:43 PM
dutchrunner
the Netherlands
Thanks RTSE . Did not know about the 2 differences GForce has with GF5R trans. Will need to get back to GForce then.
Madscientist . Mailed with McLeod about trans as they state max 500 lbs and in MoparMoscleMagazine it's 600 and in their Hemicuda (art morrison framed 528 ProCharger) it's linked to 1000 lbs. They say safe limit 500. They'r Cuda is not used with full power.
[Re: RTSE4ME]
#1969066
12/13/15 06:33 PM
12/13/15 06:33 PM
Posts: 2,128 sweden
sshemi
sweden
They make GF5R in 2 version cluthless and clutch assisted. The clutch assisted version does not pop out of gear under deceleration and can be driven on the street. The difference betwwen the two are the sliders and face plates on 1st thru 4th gears. [/quote] Gforce info they state :
They make GF5R in 2 version cluthless and clutch assisted. The clutch assisted version does not pop out of gear under deceleration and can be driven on the street. The difference betwwen the two are the sliders and face plates on 1st thru 4th gears. [/quote] Yes. No sence in running a clutchless on the street. I run a gf4a in my racecar and i would say its street able.
[Re: dutchrunner]
#1969208
12/13/15 11:40 PM
12/13/15 11:40 PM
Posts: 562 Ohio
lockjaw-express
Ohio
I have a Lenco ST1200 on order in a 5spd with a 3.10:1 first gear and 1:1 in 5th gear. I also ordered it with the heavy duty sprags.
I will try not to butcher up the tunnel too bad (I hope), but I have a feeling that it is going to take some major fitting behind a lakwood bell housing. Tim Hyatt is building the clutch/flywheel for me too.
Another thing I am going to do is also order the Passon 5spd, and my understanding it is 2 years out on order backlog...but I figure I will install that if the ST1200 is not street-able enough.
As soon as I start the install I will post pics of the progress. I have to wait until March to start the project because of recent spine/fusion surgery...I can't wait to get started!
Mark
[Re: dutchrunner]
#1969210
12/13/15 11:45 PM
12/13/15 11:45 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
I've been running a Richmond 5-speed with a Long V-gate for the last 8 years and I'm finally tired of pulling the trigger when downshifting when slow cruising. I had Liberty's face plate 1st through 4th and left 5th syncronized. I love to drag race this box but with a V-gate and face-plate it's a little tricky to hit the down shift just right when street driving. I have recently installed a street HEMI box with a good old reliable Hurst Supershifter III for easier street driving. If you can find a Richmond 5-speed with a Mopar input I would highly recommend that box. Oh and be prepared to do some floor cutting and torsion bar crossmember mods to make it fit with a V-gate because they are big. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: dutchrunner]
#1969284
12/14/15 01:54 AM
12/14/15 01:54 AM
Posts: 7,495 Minnesota
Hemi_Joel
Minnesota
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
