Trans Question... HELP PLEASE
#1968471
12/12/15 05:12 PM
12/12/15 05:12 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If the regular pressure is high will that cause the shift points to be high.. I think it does being that the governor has to match that pressure plus this has the throttle pressure added on to the regulator pressure ... also being this is a stock VB but with the shift improver kit for the 518 it doesnt like to down shift even when I come to a full stop.. I have to manually pull it into low then push the shifter up into drive... thanks for any help....anyone want to BUY a car
Re: Trans Question... Still
[Re: MR_P_BODY]
#1968529
12/12/15 06:54 PM
12/12/15 06:54 PM
Posts: 25,949 Rio Linda, CA
John_Kunkel
Rio Linda, CA
When you raise the line pressure the throttle pressure also rises. Since the governor pressure has to overcome throttle pressure in order for the upshift to occur, raising the line pressure will raise the shift points (all else being the same).
Failure to downshift at a complete stop can be either a stuck shift valve or a faulty governor....only to tell is to hook up a test gauge to the governor pressure test port; anything over 2 psi at a standstill is a faulty governor.
[Re: John_Kunkel]
#1968530
12/12/15 06:59 PM
12/12/15 06:59 PM
MR_P_BODY
Thanks John.. I figure as much on the line pressure.. as to the governor.. I thought for sure its clean and not stuck.. but that might be on the other trans I have.. if the governor is stuck why is it shifting.. but I do have to lift off the throttle to shift..I will put the gauges on it tomorrow
[Re: MR_P_BODY]
#1968545
12/12/15 07:50 PM
12/12/15 07:50 PM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
The governor may not be fully retracting and is letting some pressure bleed through.
As a funny FYI - a local trans shops fix for a sticky 518 governor was to put one of the snake oils in the fluid, and "rattle" the governor by tossing it into park at about 10MPH. I'm guessing that particular step wasn't included in the shift kit instructions.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: Evil Spirit]
#1968549
12/12/15 08:03 PM
12/12/15 08:03 PM
MR_P_BODY
As a funny FYI - a local trans shops fix for a sticky 518 governor was to put one of the snake oils in the fluid, and "rattle" the governor by tossing it into park at about 10MPH. I'm guessing that particular step wasn't included in the shift kit instructions. All Ive ever had by stuffing any trans into park at low speed was the ratcheting of the parking paw till it locked into park.. I dont understand what would be accomplished by that.. other than ripping the park gear or the paw apart.. I might try the snake oil if I do show 2+ psi at the port... I had this trans gone over by a shop AFTER I went through it.. just to be safe since I've had so much of a issue with these.. this was the first one I did myself.. the guy said everything looked great but he felt the regulator spring was way high.. he guessed it would be about 200# as a guess.. all that went into the trans was a shift improvement kit from trans-go.. I do remember a spring change but didnt think it was the regulator pressure spring.. so I'm not sure since I myself didnt put it in
[Re: dizuster]
#1968619
12/12/15 10:26 PM
12/12/15 10:26 PM
MR_P_BODY
Mike is this the 2nd trans? Same valve body, different trans, same problem?
If so points to the valve body doesn't it? I'm loosing track of whats what.. 3 trans from you and then I bought another.. it didnt have drive(if I remember right) then this one I did and had it checked.. this one is the one that was the original but I went through so its the same VB... I can swap in the other stock VB.. but I have a couple of things to try first... when you changed the stuff in the VB.. what spring did you change.. was that the regulator spring or ?.. if it was then I might just change the spring from the stock VB or change the whole VB
[Re: MR_P_BODY]
#1968633
12/12/15 10:52 PM
12/12/15 10:52 PM
Posts: 16,930 NC
440Jim
NC
... the guy said everything looked great but he felt the regulator spring was way high.. he guessed it would be about 200# as a guess... That would be very high for line pressure in a forward gear. Although the Griner valve bodies I used allowed over 200 psi, I ran mine at 165 psi. For what you are doing, I would think 120-140 would be high enough?
[Re: 440Jim]
#1968653
12/12/15 11:19 PM
12/12/15 11:19 PM
MR_P_BODY
... the guy said everything looked great but he felt the regulator spring was way high.. he guessed it would be about 200# as a guess... That would be very high for line pressure in a forward gear. Although the Griner valve bodies I used allowed over 200 psi, I ran mine at 165 psi. For what you are doing, I would think 120-140 would be high enough? Thanks Jim.. I'm gonna put the gauges on it
[Re: MR_P_BODY]
#1968793
12/13/15 03:50 AM
12/13/15 03:50 AM
Evil Spirit
Newport, Mi
As a funny FYI - a local trans shops fix for a sticky 518 governor was to put one of the snake oils in the fluid, and "rattle" the governor by tossing it into park at about 10MPH. I'm guessing that particular step wasn't included in the shift kit instructions. All Ive ever had by stuffing any trans into park at low speed was the ratcheting of the parking paw till it locked into park.. I dont understand what would be accomplished by that.. other than ripping the park gear or the paw apart.. wave: Yup. Think of where the park gear and the governor body is located. Both the parking pawl gear and the governor body are a part of the output shaft. The vibration from the ratcheting of the pawl teeth is what "rattles" the sticky governor, along with the snake oil. You don't let it grind to a stop - it's a quick in and out. I'm not blaming anybody for not wanting to try it - just saying I've seen it done, and it worked. Like I said - I doubt if you will see that tip in any manual, but I know of several techs that swear by it. Sure is easier to try than ripping out a t/case and the O/D extension housing. If it doesn't work, it had to come apart, anyways.
[Re: J_BODY]
#1968879
12/13/15 12:48 PM
12/13/15 12:48 PM
MR_P_BODY
Glad somebody finally brought up the "park trick". I'm guilty as charged and have seen it work more times than I care to think about. Trans tech showed me in my early years. I did the park thing YEARS ago as a young wrench BUT it was more of a OH damn.. then pulled it out.. but there wasnt anything wrong with the trans... I guess its worth a try if it is stuck for a last chance before pulling it... but I am looking elsewhere right now.. I think I'm gonna pull the whole VB today and put in my other one and try that
[Re: MR_P_BODY]
#1968968
12/13/15 03:30 PM
12/13/15 03:30 PM
MR_P_BODY
I have heard from a trans guy that if you have the car (on the hoist) running in forward gear then hit reverse it will spike the pressure and free up a stuck governor... any true to this or has anyone tried it...(about 20-30 MPH in forward) EDIT I am giving thought to cutting the chassis in the drive shaft loop area so I can pull the tailshaft off to get at the governor... then I will set it up so I can pin it back on... but I'll leave it off till I have it all figured out then put it back on
[Re: J_BODY]
#1968969
12/13/15 03:33 PM
12/13/15 03:33 PM
Evil Spirit
Newport, Mi
Glad somebody finally brought up the "park trick". I'm guilty as charged and have seen it work more times than I care to think about. Trans tech showed me in my early years. That is one of those "tech tips" you post, knowing that you will probably get beaten up over. Sorta like the old dumping water down the carb to get rid of cylinder carbon deposits - some people cringe at it, others swear by it. Mike, as to the "rattling" of the governor - about 10MPH, toss in park for a quick one thousand one count, then back into a forward gear. Too fast and the pawl just skims over the teeth, too slow and it will engage and lock the tires.
[Re: Evil Spirit]
#1969658
12/14/15 07:38 PM
12/14/15 07:38 PM
MR_P_BODY
I have the Rampage up on the hoist... I was thinking about cutting some tubes to get the tail shaft off... thats not gonna happen.. there isnt enough room to slide it back to get it off.. so I'll have to try the park or reverse thing to see if it'll free up... if it doesnt... I pull the engine/trans AGAIN... this is getting REAL OLD.. I am gonna change valve bodies tomorrow to see if it helps the up shift... this thing is getting closer to the burn pile EDIT does anyone know of a trans dyno in the Detroit area
[Re: MR_P_BODY]
#1969664
12/14/15 07:54 PM
12/14/15 07:54 PM
Posts: 8,032 Tulsa OK
Bad340fish
Tulsa OK
If you need to pull the motor/trans again I would be done with the OD deal. Put a 727 in it and don't sweat the RPM.
My junk knocks down 13-14MPG spinning 3500RPM on drag week for 4 years now. Its quieter and feels more "happy" then it does at lower RPM. If I put an overdrive in I would just have to drive faster lol(not that it would be a bad thing).
68 Barracuda Formula S 340
[Re: Bad340fish]
#1969668
12/14/15 08:01 PM
12/14/15 08:01 PM
MR_P_BODY
My junk knocks down 13-14MPG spinning 3500RPM on drag week for 4 years now. Its quieter and feels more "happy" then it does at lower RPM. If I put an overdrive in I would just have to drive faster lol(not that it would be a bad thing). Too late for that.. I would have to cut out a bunch of tubes to relocate the trans mount... I have all the gears its just the upshift and downshift.. if I want to down shift I can pull the shifter... the upshift I think is the valve body but way too high of rpms
[Re: MR_P_BODY]
#1969697
12/14/15 08:46 PM
12/14/15 08:46 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
You need to assess your situation from outside of the box you're stuck in. First, yes. Try the valve body. But if you need to pull the trans again, change what needs to be changed to get the trans out on its own. You have the skill, the equipment and the time to do it. You can't tell me that after all you've been through, that it would not be worth some extra time to make things easier on yourself. Sorry for the tough love, but damn...
[Re: TRENDZ]
#1969708
12/14/15 08:59 PM
12/14/15 08:59 PM
MR_P_BODY
You need to assess your situation from outside of the box you're stuck in. First, yes. Try the valve body. But if you need to pull the trans again, change what needs to be changed to get the trans out on its own. You have the skill, the equipment and the time to do it. You can't tell me that after all you've been through, that it would not be worth some extra time to make things easier on yourself. Sorry for the tough love, but damn... That ISNT gonna happen.. I would have to cut the WHOLE interior out and start over.. plus I would have to cut part of the dash(lower part) then cut out my seat mounts and the drive shaft loop and the X-bracing on the chassis... I built this thinking I wouldnt be pulling the trans... IF I could move the whole interior I wouldnt have room for myself.. hell I had to move the engine/trans over 1" to the right to give me just a bit of room..... so NOPE none of that is gonna happen.. if needed I'll pull the engine/trans one again.. but I will find a trans dyno to test it before it goes back in.. I can see you have never built a SMALL car... I deal in .010" for clearance on a lot of the stuff
[Re: MR_P_BODY]
#1970266
12/15/15 05:24 PM
12/15/15 05:24 PM
MR_P_BODY
I put a gauge on the governor port today.. it shows zero pressure in gear at zero speed... as I increased the speed it shows the pressure going up.. I brought it back to zero speed.. showed zero pressure.. as I brought it up in speed again it showed zero pressure this time... whats going on here.. also what port can I read the regulator pressure.... thanks for any help
