Re: 318 build!!!!!!!!!!!!!!!!!!!!
[Re: erick72]
#196789
02/06/09 09:21 PM
02/06/09 09:21 PM
RapidRobert
(1) the BB one is very good, the SB one I am going to find out(as I have one in hand) but it should be good (2) I dont know (3) I dont know (4) no
[Re: RapidRobert]
#196790
02/06/09 10:05 PM
02/06/09 10:05 PM
Posts: 580 Detroit,Michigan USA!
erick72
haha im confused?
are you reffering to me?lol
[Re: denfireguy]
#196793
02/06/09 11:26 PM
02/06/09 11:26 PM
Posts: 2,267 ILLINOIS
volaredon
ILLINOIS
I found several places cheaper than them including Hughes!!! CCH wants $350 too high; I found some for $229 each; EQ's national sales Manager has them listed on Ebay for that! These are "bare" prices/I have plenty of valves from bum cracked heads and access to valve grinding equip to "clean them up" before installing them.
I believe the CCH heads are not bare but have the 2.02 intakes, springs and keepers. I have not checked out Carolina but will today. Craig
I was comparing CCH's price, for BARE 1.94 heads vs. Hughes' BARE 1.94 heads vs the place I got em from which were also BARE 1.94 heads; NOT BARE heads from one vendor, vs assembled/prepped heads from another; that's like apples to oranges; with all these cracked heads I have plenty of Magnum head gear to pick from and access to at least a few valve grinding machines!!!! and with all the money I've wasted, buying OEM used Mag heads and machine shop labor for degreasing/hot tanking and crack checking I need to save money SOMEWHERE!!!!
[Re: erick72]
#196794
02/07/09 12:02 AM
02/07/09 12:02 AM
erick72
ok
so im confused.the holley aluminum street dominator intake is no good?
oh and by the way
i found a good deal
a cam and lifters
idk what the cam is but the numbers are
.398 260 degree .420270
is that any good?
also will long tube headers out of a 74 valiant four door with a 318 fit my 318 in my 72 satellite with power steering?
the guy wants 100 bucks for the two things.both new!
does anyone know?
[Re: erick72]
#196795
02/07/09 12:40 AM
02/07/09 12:40 AM
Posts: 3,445 N.Wilkesboro,NC
DusterKrazy
N.Wilkesboro,NC
ok
oh and by the way
i found a good deal
a cam and lifters
is that any good?
does anyone know?
Thats a really good deal it sounds like. But Id reccomend the 430 lift mopar performance 340 grind cam. They work well in a 318
[Re: DusterKrazy]
#196796
02/07/09 10:22 AM
02/07/09 10:22 AM
erick72
ok
oh and by the way
i found a good deal
a cam and lifters
is that any good?
does anyone know?
the guy said it says "high performance cam for 273-360 mopar.it has new lifters too!what does it sound like?a stock 340 cam or a mild 318 cam?
but someone told me this
do i need a roller cam to do the magnum head swap?????
i thought i was fine with a the hydraulic kind listed above.
also will these headers bolt onto the magnum heads?or do i need special ones?
[Re: FuryUs]
#196798
02/07/09 12:13 PM
02/07/09 12:13 PM
erick72
That cam will work--you don't need a roller. The headers will bolt to the Magnum heads (ports are a little different, but they should seal), but I don't think A body headers will work in a B body.
well i was thinking they just might because the little a body has a 318,power steering and a full size starter adn my engine bay is bigger anyways.what would get in the way?
are the lifters he has ok too?i just need the oil through pushrods right?
[Re: volaredon]
#196800
02/08/09 11:15 PM
02/08/09 11:15 PM
erick72
You could NOT use a factory style roller setup if that is your original block; they did not set the blocks up for a roller cam before 1985-ish. You'd have to go with some sort of aftermarket design (read; way more expensive) to go roller on that engine. But as Mopars had the largest diameter lifters you can actually run a bigger cam than a Generic Motors engine could IF the rest of your build can support one. but IF you go Magnum heads with stock Magnum rockers, etc, your 1.6 rocker ratio will make any cam you use in that engine seem a little "bigger" as all 91-older SB Mopars only had a 1.5:1 rocker ratio. (you COULD go aftermarket rockers and find 1.5s for the Magnum setup but that would be a step backwards)
its ok oller is expensive.i was just making sure i didnt need them!
so im taking it the headers wont fit?
[Re: volaredon]
#196802
02/14/09 01:48 PM
02/14/09 01:48 PM
erick72
How did you get that out of it (standard LA headers not fitting) according to what I see in this very thread they should be fine; as far as "a" body headers in your "b" body--- most catalogs list all Mopar bodies together just whether you have a big or small block (318 is SB if you were wondering) is what matters for headers on your combo. Should fit fine!
good im gonna go get them and see!
