Re: A body K frame question
[Re: dustyswinger]
#1965398
12/08/15 04:08 AM
12/08/15 04:08 AM
RapidRobert
Not sure if you could put the mts on the front side of the block ears or not. Any possibility you could mod the trans mt and or crossmember to take care of it on that end? SB I am assuming. FYI the 876 pan the sump starts ~2" back from a plumb line straight down from the very front pan lip and ~4" on the 392 pan. both sumps are ~8" long & each pan takes a different pickup.
[Re: dustyswinger]
#1965799
12/08/15 07:38 PM
12/08/15 07:38 PM
RapidRobert
The electric cooling fan doesn't fit between the water pump and the radiator anymore Is that the only fitment issue you are having with this?
