Re: Mopar pan porn
[Re: dthemi]
#1965922
12/08/15 10:36 PM
12/08/15 10:36 PM
Superfreak
Superfreak
Re: Mopar pan porn
[Re: dthemi]
#1966146
12/09/15 03:49 AM
12/09/15 03:49 AM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
Dailey makes bad a$$ stuff for sure. Thought about going that route with mine and decided this time to use the $$$ elsewhere. Will get this stuff when freshened up if I don't sell it before then..
Re: Mopar pan porn
[Re: AndyF]
#1966340
12/09/15 03:07 PM
12/09/15 03:07 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I had a pan and pump that was similar to that.. it was from a early proto type viper engine... yeah they are pretty.. and to be hidden under the engine where you really cant see it
Re: Mopar pan porn
[Re: dthemi]
#1966441
12/09/15 05:46 PM
12/09/15 05:46 PM
Posts: 656 Florida
CJD AUTOMOTIVE
That is so sweet! Bill Dailey is such a great guy. He builds stuff for all the mega buck Cup, off road, road course, etc, guys, but treats every customer as if they are the most important. He spent the time to spec my entire system even though I only bought the pump. He ask a ton of questions to make sure you get exactly the right pump for your application. Can't say enough about him. Here's my 5 stage:
Craig Scholl CJD Automotive, LLC Jacksonville, FL www.CJDAUTOMOTIVE.com904-400-1802 "I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
Re: Mopar pan porn
[Re: sc4400]
#1966539
12/09/15 08:45 PM
12/09/15 08:45 PM
Posts: 3,097 back in Georgia
dthemi
back in Georgia
So help out my ignorance. Why 2 pumps? I understand the multi stage pump. And would there actually be a price on that?
I'm thinking it would look good on the coffee table!
RIP The pump that bolts on the pan is scavenge only, running twice crank speed. The pressure section goes in the factory oil pump location, and runs half crank speed. Goal being, outer space vacuum in the crank case with as little oil flying around as possible. CJD, you're right. Bill treated me as if I were a prostock front runner.
Re: Mopar pan porn
[Re: Monte_Smith]
#1967183
12/10/15 04:35 PM
12/10/15 04:35 PM
dthemi
back in Georgia
The ONLY downside to the Dailey stuff, is that it is kind of heavy and makes the motor somewhat hard to work on if you need to drop the pan quickly Yeah, it'll be interesting to weigh it up against a box dry pan. This one is profile milled everywhere it could be so I'll weigh it against some of the other stuff I have after pri. Might be close being absent all the lines and fittings. I'm sure when you factor in a tank the whole set up gets heavier. The pan rail bolts don't pass through the scavenge ports, so it'll drop straight off even with the scavenge pump attached. I went this route mostly to get the crank center close to the ground, and feel safe about cranking the vacuum to it. 15inches was almost too much wet. I'm going for 20+ now if I can get it. Also Monte, if the offer is still available, I need a pair of Gen3 1150's in hard gray. Could/would you PM me about it?, Thanks man.
Re: Mopar pan porn
[Re: dthemi]
#1967381
12/10/15 10:27 PM
12/10/15 10:27 PM
Posts: 8,871 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I've yet to see ANY dry sump system that weighs less than a pan pickup and pump !!!
Re: Mopar pan porn
[Re: Stanton]
#1967399
12/10/15 10:59 PM
12/10/15 10:59 PM
MR_P_BODY
I've yet to see ANY dry sump system that weighs less than a pan pickup and pump !!! They wont due to all the added stuff.. tank, pump lines.. but then you get vac without another pump
Re: Mopar pan porn
[Re: MR_P_BODY]
#1967406
12/10/15 11:07 PM
12/10/15 11:07 PM
dthemi
back in Georgia
I've yet to see ANY dry sump system that weighs less than a pan pickup and pump !!! They wont due to all the added stuff.. tank, pump lines.. but then you get vac without another pump Exactly. Still a bit heavier,but not too bad. Then Ill carry 4 fewer quarts of oil too.
Re: Mopar pan porn
[Re: Defbob]
#1967415
12/10/15 11:15 PM
12/10/15 11:15 PM
dthemi
back in Georgia
That looks a little better than the NRE Hemi pan Looks as slick to me Defbob. I'm picking up some noonan heads and billet roots efi manifold from them at pri on sat. Can't wait to get one of their water blocks. Hope it wont be a waiting game. hows your noonan project coming, and which rockers are you going with?
