CD/Crane/Chet Herbert Camshaft Identification
#1964306
12/06/15 12:52 PM
12/06/15 12:52 PM
Posts: 577 Arkansas
Adrielp
Arkansas
I've got an old camshaft of which I'm trying to the specifications to. From what I've read, it seems to be a Crane Cam Core with a Chet Herbert grind but in searching there were two cams with two different specs that used the 689356 number so I'm trying to verify the cam information. Please, can someone help me in finding the original cam specs. Also, this cam is specifically for a Big Block Mopar Wedge engine(3 bolt).
The number on the rear of the camshaft is: 689356(I believe this is the part number) 8A2A(I believe this is the heat treat batch number) The number on the front of the camshaft is: CD274-06 then 274 is listed again by itself. Also No. 4586 is on the front of the cam as well.
Adriel Paradise Substation Design Engineer III
Re: CD/Crane/Chet Herbert Camshaft Identification
[Re: Adrielp]
#1964946
12/07/15 04:08 PM
12/07/15 04:08 PM
Posts: 3,210 robin hood country
deaks
robin hood country
What a coincidence, i was clearing the back bedroom the other day and found a cam i bought 2 or 3 yrs ago, it's a Herbert 689356 D6C roller cam, the card says .625/.625 at 1.5 275 int,283 exh at .050, lobe center 108, center line 107, at .050 int opens 36 close 59 exh opens 72 close 30 valve lash .025/.025 Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: Adrielp]
#1965079
12/07/15 07:53 PM
12/07/15 07:53 PM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
If it's a roller, here's my guess.... CD - cam dynamics 274 - duration @ .050 4586 - lobe lift, .4586" 06 - 106 lsa
More than likely a single pattern cam. It would be easy enough to measure the lobe lift to verify it was close to .458.
If it's a flat tappet cam, then it's a judgement call as to whether the 274 is duration @ .050 or advertised, and I think I would let the lobe lift be the deciding factor. If it was like .300-.310 it's more than likely advertised duration, if it's like .340+ then it's likely duration @ .050.
