92 Dodge van speedometer problem #1965093
12/07/15 08:22 PM
12/07/15 08:22 PM
Wills Point, Texas
Hugh Jorgan Online work OP
Hugh Jorgan  Online Work OP
Wills Point, Texas
I have a 92 dodge 2500 cargo van, 5.9 w/518 with a speedometer issue. It has always read accurately in the past but recently reads a fraction of the actual speed. Say I'm running along at 70mph, it reads 20mph. The needle does not bounce around, but will hold steady. What would cause this? Thanks in advance.
Re: 92 Dodge van speedometer problem [Re: Hugh Jorgan] #1965363
12/08/15 02:07 AM
12/08/15 02:07 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
1) The speedo cable is dry and /or binding in the housing.
2) Cruise control? Does the speedo cable run through the cruise control diaphragm?
3) the speedo gear on the trans is dead (or near dead) is there an electric pickup on the speedo gear housing?
4) The speedo head is dead or near dead.
5) If there is a speedo correction device, it could be bad.
Gene
Re: 92 Dodge van speedometer problem [Re: Hugh Jorgan] #1965471
12/08/15 11:22 AM
12/08/15 11:22 AM
scratchnfotraction Offline
does the 92 have the VSS speedo gear housing with a wire/plug at the speedo gear? long or short speedo pinion gear shaft?
may need the unit replaced.
Re: 92 Dodge van speedometer problem [Re: Hugh Jorgan] #1965690
12/08/15 05:02 PM
12/08/15 05:02 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Does the odometer record accurately?
