Re: fuel injectors
[Re: ahy]
#1965474
12/08/15 11:29 AM
12/08/15 11:29 AM
Posts: 10,714 North Dakota
6PakBee
North Dakota
The only problem that I've ever had with high mileage injectors is leakage. In your case I'd recommend checking your codes. When I've had a sudden nosedive in mileage typically it has been a drifting O2 sensor, not injectors.
Re: fuel injectors
[Re: Alexdodge]
#1965785
12/08/15 07:14 PM
12/08/15 07:14 PM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
I see this every winter in Ohio,customers start complaining about poor fuel economy and longer crank times when starting. The thermostat stays closed longer not letting some of the sensors see the hot water like they did in warmer weather. The fuel trim stays rich longer and you will burn more fuel. Now about that fuel in Ohio In most counties they add more alcohol to the fuel in winter and thus your fuel consumption goes up when your A/F sensor sees a lean condition and adds more fuel until it's happy your engine isn't going going lean. That's just my guess Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: fuel injectors
[Re: Alexdodge]
#1966035
12/09/15 12:37 AM
12/09/15 12:37 AM
6PakBee
North Dakota
The internet is our friend. There are quite a few sites that cover this if you decide to do it.
Re: fuel injectors
[Re: 6PakBee]
#1966310
12/09/15 02:42 PM
12/09/15 02:42 PM
dogdays
Had exactly the same thing happen on wife's car and after a while of poor mpg the Check Engine Light came on. One upstream O2 sensor later, mileage returned and CEL went off. This was about 140K miles. I like NTK sensors.
R.
Re: fuel injectors
[Re: Alexdodge]
#1966368
12/09/15 03:45 PM
12/09/15 03:45 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
You need to watch the 02 sensors on the live data stream, a code may or may not be set by a contaminated 02 sensor. The upstream one is the only one that matters. It could dump up to %25 extra fuel before the code is triggered, more than about %5-%10 usually means something is getting skewed.
Avoid the snake oil at the parts store for cleaning injectors, just try a couple tanks of premium fuel from a tier 1 supplier, they have way more cleaner than normal gasoline and since the engineers supplied it already mixed they probably knew what they were doing better than someone bottling acetone in their basement.
I am not sure about the 05 but early 4.7 had a single squirt hole in the injector, a swap to some ferd 4.6 infectors usually nets a little better MPG as they atomize the fuel better, if your swapping injectors anyhow.
A car usually gets significantly worse MPG in the winter because fuel is not evaporated as good. Gear oil gets thick and hard to stir, oil gets thick, PS fluid gets thick, trans fluid gets thick...
Alcohol content usually goes down in winter because it don't evaporate as good and hinders cold start a hair, of course E-85 never really made my cars hard to start but that is what the fuel makers say.
Re: fuel injectors
[Re: Alexdodge]
#1966633
12/09/15 11:03 PM
12/09/15 11:03 PM
Posts: 261 Eastern ohio
Alexdodge
Eastern ohio
So where is this upstream sensor located on the 05 4.7 engine
Re: fuel injectors
[Re: Alexdodge]
#1966736
12/10/15 12:47 AM
12/10/15 12:47 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
So where is this upstream sensor located on the 05 4.7 engine Gonna be real honest here, if you don't already know this then this job is probably not for you. You have two upstream O2 sensors, one on each side of the engine, they are UPSTREAM of the cats. Think about how the exhaust flows and which direction is upstream. Without a scan tool you'll be guess which one, if any, of the upstream sensors is bad. may as well replace both rather than one of them if you're going to do it. Which, at this point, you are just throwing parts at a maybe problem.
