Offset head dowels for BB? Minimum radial valve clearance? #1964471
12/06/15 05:58 PM
12/06/15 05:58 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
Two related questions:
1. Does anyone sell (or can make?) offset cylinder head dowels for BB Mopars? I think for BBs they're only .250" OD, and the smallest offset dowels I see listed anywhere are ~ .310" for SBM / SBC.
2. What is the recommended minimum radial valve clearance (clearance between edge of valve and valve relief in piston)?
Thanks,
Brad
Re: Offset head dowels for BB? Minimum radial valve clearance? [Re: BradH] #1964473
12/06/15 06:03 PM
12/06/15 06:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont know about the BB dowls.. but on the radial
clearance I have been as low as .030 but normal is .050
wave
Re: Offset head dowels for BB? Minimum radial valve clearance? [Re: BradH] #1964518
12/06/15 07:51 PM
12/06/15 07:51 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Thanks,
Brad
The offset dowels are easy to make with an offset jig on a surface grinder.
My surface grinder is down right now or I could make them for you. I am replacing my old manual one with a hydraulic unit but am rebuilding it before I put it in service. I am a month or two away from finishing it.
Re: Offset head dowels for BB? Minimum radial valve clearance? [Re: BradH] #1964905
12/07/15 02:36 PM
12/07/15 02:36 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
These say they are for a Mopar big block...
Your milage may vary...
http://proshop.summitracing.com///search...ar-big-block-rb
Re: Offset head dowels for BB? Minimum radial valve clearance? [Re: BradH] #1964926
12/07/15 03:06 PM
12/07/15 03:06 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
I was thinking bbc was the same. I have a friend that has made the offset dowl pins. One thing to remember is at some point you have to enlarge the bolt holes also. If I was going for optimum performance I would sonic check the block and cnc the cylinder bores as high as possible along with the offset dowels.
Getting old just means you were smarter than some and luckier than others.
Re: Offset head dowels for BB? Minimum radial valve clearance? [Re: BradH] #1964940
12/07/15 03:51 PM
12/07/15 03:51 PM
New York
polyspheric Offline
polyspheric  Offline
New York
X2 - with the dowels in place you want the bolts to slip into the head with effort.
Boffin Emeritus
Re: Offset head dowels for BB? Minimum radial valve clearance? [Re: dannysbee] #1964993
12/07/15 05:06 PM
12/07/15 05:06 PM
BB chevy are no where near the same as the ones on our B, RB and gen2 hemi motor, they won't work tsk
Re: Offset head dowels for BB? Minimum radial valve clearance? [Re: BradH] #1965004
12/07/15 05:23 PM
12/07/15 05:23 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
Couldn't you just move the dowel holes? I think I remember reading that in RAMM's EMC 2013 470 B stroker thread. That was a bit more trick though with the heavy angle milling, moving .100, elongating and spot facing for the head bolts.
Re: Offset head dowels for BB? Minimum radial valve clearance? [Re: CTD5.9] #1965124
12/07/15 09:16 PM
12/07/15 09:16 PM
in the middle
dodger mope Offline
dodger mope  Offline
in the middle
a quick and easy small movement of the head is to use a drift on the dowel and little smack with a hammer.moved a lot hemi heads that way.
Re: Offset head dowels for BB? Minimum radial valve clearance? [Re: BradH] #1965130
12/07/15 09:31 PM
12/07/15 09:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Brad.. when you do find your off set pins make sure
they set down flat on the block without the gasket..
I've been there before when the head didnt
wave
Re: Offset head dowels for BB? Minimum radial valve clearance? [Re: BradH] #2647089
04/20/19 03:07 AM
04/20/19 03:07 AM
upstate, New York
jvcuda Offline
jvcuda  Offline
upstate, New York
Thanks,
Brad
found this in the archives from dec 2015
