Lets See those Turbo Hemis #1964103
12/06/15 12:45 AM
12/06/15 12:45 AM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Kinda bored, what performance level have you guys got to with a single turbo and a Hemi?
Re: Lets See those Turbo Hemis [Re: Dragula] #1964312
12/06/15 01:01 PM
12/06/15 01:01 PM
Portersville, Pa
1badx Offline
1badx  Offline
Portersville, Pa
Re: Lets See those Turbo Hemis [Re: 1badx] #1964481
12/06/15 06:26 PM
12/06/15 06:26 PM
ghinmi Offline
ghinmi  Offline
Does not run yet so no performance numbers. Budget deal, stock 09+ 5.7 with a reground cam and vvt delete. Full stainless hot side feeding a Bullseye billet S366. Ford cable throttle body and 80 lb injectors, ditched the factory ecu for a Holley HP EFI. Hoping for 500 whp on pump gas and instant spool.
1975 Jeep Cherokee compound turbo 5.7 Hemi/6 speed AutoX/Drag/Street.
9.97 @ 140 slicks, 10.74 in autox trim
Re: Lets See those Turbo Hemis [Re: Dragula] #1964602
12/06/15 10:03 PM
12/06/15 10:03 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Mopar to the bone!!!
Re: Lets See those Turbo Hemis [Re: ghinmi] #1965151
12/07/15 10:21 PM
12/07/15 10:21 PM
USA
hudsonhornet7x Offline
USA
What did you do for the VVT delete? Was it the Nutter Racing Kit?
Re: Lets See those Turbo Hemis [Re: hudsonhornet7x] #1965215
12/07/15 11:31 PM
12/07/15 11:31 PM
ghinmi Offline
ghinmi  Offline
I bought the Comp Cams lockout kit but haven't installed it yet. Pretty simple setup. The issue is that you have no way of degreeing the cam. I'm going to set it up, see how much it needs moved, and cut a new keyway in the crank gear to get it right.
Re: Lets See those Turbo Hemis [Re: ghinmi] #1965277
12/08/15 12:25 AM
12/08/15 12:25 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Cool whip! Is that an old Jeep? (Sorry not to up on the older Jeeps) is it AWD or RWD?
Re: Lets See those Turbo Hemis [Re: WO23Coronet] #1965307
12/08/15 12:58 AM
12/08/15 12:58 AM
ghinmi Offline
ghinmi  Offline
Yep, it's an '83 Cherokee Laredo. It's on a modified and shortened 2wd Chevy C10 frame. Going to autocross it.
