Can you help identify these wheels and #1963661
12/05/15 12:01 PM
12/05/15 12:01 PM
Toledo, Ohio
70FJ5383 Offline OP
70FJ5383  Offline OP
Toledo, Ohio
where do you get your info. Is there a publication that has wheel part numbers and applications? Thanks
Re: Can you help identify these wheels and [Re: 70FJ5383] #1963738
12/05/15 01:53 PM
12/05/15 01:53 PM
md
mopars4ever Offline
mopars4ever  Offline
md
3633171 I`m pretty sure it is a truck wheel late 70`s early 80`s IIRC. Should be a 15 x 5.5
3580057 should be 72-74 C-body
I think Galen had wheel numbers in his book. I don`t have one to check.
Re: Can you help identify these wheels and [Re: 70FJ5383] #1963741
12/05/15 01:56 PM
12/05/15 01:56 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
3580057 72-74 C body 14x5.5 stamped steel wheel
Can't help with the other part number......probably a truck or van wheel from the same time frame as the C body wheel.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Can you help identify these wheels and [Re: 70gtx440dana] #1963849
12/05/15 05:11 PM
12/05/15 05:11 PM
Toledo, Ohio
70FJ5383 Offline OP
70FJ5383  Offline OP
Toledo, Ohio
Thanks.
