i do it a few different ways depending on the customer. a lot of times I will blast twice or even three times depending on what kind of job they are doing.
blast the car.. needs quarters. cut the quarters now you have access to the wheelhouses and trunk extensions, clean those in the second blast. same goes for inner fenders, trunk floor ect.
some guys want the edm removed from replaced panels after replacement. quick reblast
some guys want the whole car done again once panels are replaced before epoxy
blast the car and find rust in the floors , remove the floor and blast inside the frame rails.
everybody has their own way of doing it. if your on a budget. I would remove your rusty stuff first then blast that should get the majority of the hard to reach spots. I would not replace panels before blasting as blasting allways turns up surprises.
