1970 E Body engine off set? #1962127
12/02/15 11:57 PM
12/02/15 11:57 PM
USA
Z
z70dodge Offline OP
z70dodge  Offline OP
Z
USA
I put a 318 in my original 6 cylinder 70 challenger and the engine is not directly in the middle of the engine compartment? I did the K frame and correct motor mounts. Is this normal?
Re: 1970 E Body engine off set? [Re: z70dodge] #1962138
12/03/15 12:08 AM
12/03/15 12:08 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
It will be offset about an inch to the passenger side.
Re: 1970 E Body engine off set? [Re: z70dodge] #1962142
12/03/15 12:13 AM
12/03/15 12:13 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The offset is for steering column / box clearance.
It is not as noticeable with a /6, but they are offset as well.
Re: 1970 E Body engine off set? [Re: Alaskan_TA] #1963362
12/04/15 09:25 PM
12/04/15 09:25 PM
USA
Z
z70dodge Offline OP
z70dodge  Offline OP
Z
USA
Thanks guys!
Re: 1970 E Body engine off set? [Re: z70dodge] #1963423
12/04/15 11:11 PM
12/04/15 11:11 PM
Ohio
shorthorse Offline
shorthorse  Offline
Ohio
Found this on TTI's website -
