All the NHRA rule books I've read in the past said you had to have a specified thickness of steel, thinner, or thicker aluminum. I don't remember any wording involving cardboard but I haven't had a printed rule book since NHRA went cheap on us long time members back in 2010 or so
I've been rousted in NHRA tech here in the northwest about having to much clearance(more than 1/16 inch
) between the aluminum seat partision and the rear roll bar downbars passing through it
BTW, you really need to know if the battery is in the trunk and the same thing on the fuel filler being in the trunk or passing through the trunk for this rule
