Page 2 of 4 1 2 3 4
Re: Ok fellas I'm stumped. [Re: Al_Alguire] #1958246
11/26/15 11:30 AM
11/26/15 11:30 AM
Locomotion Online content
Locomotion  Online Content
Could it be an over-rich condition when the accellerator pump duration overlaps the main circuit activation, which may happen to be at 3,600?
I've had issues with a bog/flat spot footbraking and been working on shortening the pump duration. Don't have an A/F meter yet.
Bringing the rpm up to 2,200-2,500 may start the main circuit, but it also reduces the volume and duration of pump shot delivery over what you get from idle.
Re: Ok fellas I'm stumped. [Re: Al_Alguire] #1958252
11/26/15 11:42 AM
11/26/15 11:42 AM
Jerry Kathe Offline
Jerry Kathe  Offline
A rich transition would do that, but I cant believe he used the same carb from gas to e85....on gas it would puff a cloud of black smoke during the occurrence....kinda easy to see on a pipe rack and freaky odds that two carbs would have the same problem.
Re: Ok fellas I'm stumped. [Re: Jerry Kathe] #1958261
11/26/15 12:09 PM
11/26/15 12:09 PM
I think it may be a common problem which could exist in both carbs. It's sometimes difficult to convince yourself that "less" is better as opposed to "bigger is better". It's not always obvious.
I recently replaced a well used engine with one having basically the same parts/combo. That changed the carb tune-up to the point that I originally thought I screwed something up in the build! Must have been the ring seal.
But as they say...."Leave no stone unturned." If expected fixes don't work, you have to start with the unexpected ones.
Does over-rich E85 cause black smoke as bad as gas?
Re: Ok fellas I'm stumped. [Re: Al_Alguire] #1958271
11/26/15 12:26 PM
11/26/15 12:26 PM
Az
Crizila Offline
Crizila  Offline
Az
If adding timing helps, it's going lean at that rpm. Could try smaller hi speed air bleeds.
Fastest 300
Re: Ok fellas I'm stumped. [Re: Al_Alguire] #1958272
11/26/15 12:27 PM
11/26/15 12:27 PM
Las Vegas
Al_Alguire Offline OP
Las Vegas
TDC WAS accurate upon assembly. After I left for DC my son and a friend had to change balancers(from Chevy to Mopar front) so possibly there was an issue there I was not here so not sure. It happened on both gas and E85 with 2 different carbs. I have been overly cautious with the timing but cannot and do not believe it is actually at 48, am assuming that something has happened there. BUt the plugs are showing it wants more timing still. Definitely has me baffled for sure. Oh yeah did it with 2 different E85 carbs as well, so pretty sure it is NOT a carb issue.
Re: Ok fellas I'm stumped. [Re: Al_Alguire] #1958282
11/26/15 12:39 PM
11/26/15 12:39 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Total w.a.g. on my part, but if it isn't a carb or ignition issue, I'd be suspecting the intake runner volume in conjunction with the small(er) engine size and moderate compression has a reversion issue at that low RPM. The slower burn rate of E85 vs gas would make it worse, too.
Re: Ok fellas I'm stumped. [Re: Al_Alguire] #1958299
11/26/15 01:11 PM
11/26/15 01:11 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
I've had that issue with e85 a couple times. One time it was cured by running 180 water temp. The lower the compression the more temp it wanted.
Chased another on e85 and wound up having someone wack the throttle while using 2 spray bottles with e85 in them, and shooting extra fuel in at the same time. Came right up, so we were already at max on the pumps, so fattened up the idle circuit a bunch and went small on the bleed too. Like just a dart was saying
I've been using vp C85 exclusively for a while now, and I'll never go back. Runs like gas, great cooling, and zero corrosion. Makes way better power than pump too. Straight up on the break in everything so far
Re: Ok fellas I'm stumped. [Re: Al_Alguire] #1958306
11/26/15 01:24 PM
11/26/15 01:24 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Fun stuff Al.
If I could not use a spark plug type piston stop to verify TDC, and the plugs are a reasonable heat range.
I would keep putting timing in it until it quit improving or it slowed down and check the plugs to verify.
But I have also been known to color outside the lines.
"Just a Bracket car dressed up like a streetcar"
Re: Ok fellas I'm stumped. [Re: Al_Alguire] #1958311
11/26/15 01:32 PM
11/26/15 01:32 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
If you don't have time to verify TDC.. add two degrees at a time until comes up on the brake cleanly. With the two step out of the equation equation I don't think you'll get 85 to detonate with that engine combo just my two cents.good luck 🚦👍
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Ok fellas I'm stumped. [Re: dthemi] #1958313
11/26/15 01:35 PM
11/26/15 01:35 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Happy TG ALL. Here's my 2 cents...You have a small motor with "big" heads and low compression (as you admit, it's using pieced together parts) I'll bet the biggest contributor is a dip in the torq curve not allowing the converter to drive thru to it's highest stall at the line. I think it's something a camshaft change could fix, might help advancing the current one. Among other 'minor' issues contributing to the problem that have already been discussed.
Re: Ok fellas I'm stumped. [Re: WHITEDART] #1958317
11/26/15 01:41 PM
11/26/15 01:41 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
It's the converter/s, my twocents I like the idea of no 2 step, go as high as the converter will go. My small block Chevy buddies do that all the time to get them to "go".
Re: Ok fellas I'm stumped. [Re: Al_Alguire] #1958323
11/26/15 01:50 PM
11/26/15 01:50 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Sounds like you have narrowed it down to an ignition problem. First, I would drill a 3/8" hole in the cap inline from plug 1 to coil lead. Use a timing light to verify rotor phasing. I suspect it is off and spark is jumping to the next cylinder in line. If it does show OK, an easy patch would be wire up a timing retard to kick in just above launch rpm and crank up your base timing to get it up on the chip. To be safe, pull out the same amount to the retard module, that you are adding to base timing.
[image][/image]
Re: Ok fellas I'm stumped. [Re: sgcuda] #1958341
11/26/15 02:06 PM
11/26/15 02:06 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Al,
It sounds like the same problem I had with the 572 predator when I had a converter that was too tight for the head flow. Several things would help it besides that, but it would be cam, compression, can timing etc. I think you need a loose 8" converter. Also, put a piston stop in #1 and find TDC. If you are really running 48*, you already know that can't be good. Where does it dead stall? Is it lazy there too?
Re: Ok fellas I'm stumped. [Re: Al_Alguire] #1958347
11/26/15 02:17 PM
11/26/15 02:17 PM
ky
68roadrunner Offline
ky
i am not sure if it will run 5.2s . my 499 only went 5.0s at the best.
hope you get it fiqured out.
Re: Ok fellas I'm stumped. [Re: Al_Alguire] #1958364
11/26/15 02:38 PM
11/26/15 02:38 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I figure it's the carb
Re: Ok fellas I'm stumped. [Re: Al_Alguire] #1958391
11/26/15 03:33 PM
11/26/15 03:33 PM
AndyF Offline
AndyF  Offline
Do you have a compression gauge with you? Might be interesting to pull the plugs and spin it over and see what the cranking compression is. My guess is that it is super low.
Re: Ok fellas I'm stumped. [Re: Al_Alguire] #1958393
11/26/15 03:40 PM
11/26/15 03:40 PM
gregsdart Offline
gregsdart  Offline
I was going to say fat mid range, but you have tried two carbs. I had a fuel injector that was super fat in the mid throttle settings and caused similar grief. Will it flash when not fully up to temp? I am thinking of a test when it is as cold as you can without hurting parts. That might give you some info. You could also go way tight on plug gap for a test, to see if the ignition is going away (.020?)
Re: Ok fellas I'm stumped. [Re: Al_Alguire] #1958395
11/26/15 03:44 PM
11/26/15 03:44 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Electrical
Boffin Emeritus
Re: Ok fellas I'm stumped. [Re: Al_Alguire] #1958404
11/26/15 04:04 PM
11/26/15 04:04 PM
Az
Crizila Offline
Crizila  Offline
Az
Got an A/F gauge on it? That could eliminate a fuel issue.
Fastest 300
Re: Ok fellas I'm stumped. [Re: AndyF] #1958410
11/26/15 04:11 PM
11/26/15 04:11 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
x2. If it isn't the carb (worth putting a wideband on it for a pass just to check), my next guess is just a combination of E85, the altitude, 11:1 CR, aluminum heads and a roller cam. On E85 I would be surprised if you could get it to detonate at all. Might be worth advancing the cam a couple degrees to get cylinder pressure up and pick up midrange torque to pull through the converter more cleanly.
Page 2 of 4 1 2 3 4
