Re: B-Body Mini Tub ????
[Re: Chris2581]
#1958799
11/27/15 03:31 PM
11/27/15 03:31 PM
Posts: 4,179 California
mickm
California
FWIW..We put a 10.5x29.5 Firestone slick on our 70 Road Runner using a 10" wheel and trimmed the fender lip and leading edge of the wheelwell.Fit right in there. i think the 275/60 15's are around 11" x 28", and fit well. that's without any mods to the wheel well or fender lip.
[Re: Kiddart]
#1958990
11/27/15 10:37 PM
11/27/15 10:37 PM
Posts: 103 Minnesota
DLewis
Minnesota
Just finished the fab work on my 67 B body. Easily fit 315/60/15 with close to 2" more room also using the leaf relocation kit. Some pictures are posted here: 67 Build Thread I used the US Car Tool relocation kit, but didn't see a need for the mini tub kit. YMMV
[Re: DLewis]
#1960266
11/30/15 03:37 PM
11/30/15 03:37 PM
Posts: 1,550 Michigan
Kiddart
first tub cut out, man there is a tone of room hiding back there. by the way that's just surface rust I the trunk, really solid. Looks like there will be 3 1/2 inch spacer welded back in
Thank you Kiddart
[Re: Kiddart]
#1961001
12/01/15 03:38 PM
12/01/15 03:38 PM
mickm
California
first tub cut out, man there is a tone of room hiding back there. by the way that's just surface rust I the trunk, really solid. Looks like there will be 3 1/2 inch spacer welded back in keep the pictures coming, as detailed as you can. i am thinking of doing this and really want to see the process.
