Piston weight question!
#1955691
11/22/15 04:09 AM
11/22/15 04:09 AM
Posts: 742 Oak Harbor, WA
Wicked49670dart
Oak Harbor, WA
Looking for new pistons for my 496. Found some that are 10 grams heavier per piston, so 80 grams added to the bob weight. Would you run it as is, or rebalance? Thanks Matt
Re: Piston weight question!
[Re: Wicked49670dart]
#1955747
11/22/15 12:01 PM
11/22/15 12:01 PM
Posts: 4,321 Prospect, PA
BSB67
Prospect, PA
I would see if you could take 10 grams out of the new pistons.
#1955864
11/22/15 03:48 PM
11/22/15 03:48 PM
Posts: 43,308 Bend,OR USA
Cab_Burge
Lighter is better when it comes to motor parts and driveline parts ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif) Remember the rod and piston stop three times and reverse directions twice for each cranshaft revolution ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) Lighter weight parts stop easier and accelerates easier than heavy parts do ![work work](/ubbthreads/images/graemlins/custom/work.gif)
#1955934
11/22/15 05:33 PM
11/22/15 05:33 PM
Posts: 4,213 New York
polyspheric
New York
Sorry, missed the math. How does 10 grams X 8 cylinders X 50% (for reciprocating weight) = 10 grams?
Boffin Emeritus
[Re: polyspheric]
#1955950
11/22/15 05:51 PM
11/22/15 05:51 PM
Posts: 1,784 PA
W5DART66
PA
Sorry, missed the math. How does 10 grams X 8 cylinders X 50% (for reciprocating weight) = 10 grams? au Well I will never be as smart as you but you still don't get balancing an engine. Each throw is balanced. And it's one piston weight one pin weight one ring pack weight one set of lock weights. This is reciprocating weight. Rotational Is 2 of everything on that end. So it's 10 grams per throw never going to hurt a thing. You think oil on all parts in that mess is with in a gram.
[Re: BSB67]
#1955990
11/22/15 06:41 PM
11/22/15 06:41 PM
Posts: 16,932 NC
440Jim
NC
I would see if you could take 10 grams out of the new pistons. I agree. Then it would be balanced as well as before changing pistons.
[Re: W5DART66]
#1956112
11/22/15 09:48 PM
11/22/15 09:48 PM
polyspheric
New York
Being rude is the fun part, isn't it?
Boffin Emeritus
[Re: polyspheric]
#1956210
11/23/15 12:25 AM
11/23/15 12:25 AM
RapidRobert
As said 10 grams diff you're in excellent shape. However you could easily deburr a few grams off of the new piston (not sure how much but maybe even the whole 10!) and BB pins are way bigger than what is needed & even for a racing app you can safely mill up to 1/4" off of each end of the pin to lighten it to match parts for the recip part of the formula if you have a lathe (dont mind me its just my OCD/too much coffee!)
#1956237
11/23/15 01:04 AM
11/23/15 01:04 AM
Posts: 2,093 oberlin, Ohio
Rapid340
oberlin, Ohio
I wouldnt worry too much about it but you could weight a set of KING SI rod bearings. They are usually a few grams lighter than trimetal bearings. 2.5 grams for each rod set would would be parity with the heavier pistons.
They are probably more than 2.5 grams lighter but I would rather be a lighter than heavier.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
