Thoughts on Tremec five speeds
#1954853
11/20/15 01:41 PM
11/20/15 01:41 PM
Posts: 4,225 Bloomington, IN
HoosierTA
Bloomington, IN
What is the consensus nowadays on going to the five speed manual?
I am about to get my R/T to the shop, and had contacted Brewers about rebuilding my 4 speed. Then the idea of just putting a five speed came to mind. I haven't seen any posts lately about the preferred company,customer service, and how they are working.
I know some 70 Challengers may need a slight modification on the floor pan.
'70 Challenger R/T 383 '16 Hemi Durango SSV (work vehicle) '15 Ram Police SSV
Re: Thoughts on Tremec five speeds
[Re: ahy]
#1955280
11/21/15 11:45 AM
11/21/15 11:45 AM
DaytonaTurbo
Manitoba, Canada
I understand they may get hard shifting much over 6000 RPM but my stroker does not need to rev too high so not a problem.
You know, that comment is one that brings back memories of guys on here complaining that in the 6000-6500 rpm and up zone, these transmissions don't want to shift, at least not willingly.
[Re: HoosierTA]
#1955601
11/21/15 11:32 PM
11/21/15 11:32 PM
Posts: 1,708 S. Il. U.S.A.
5spdcuda
S. Il. U.S.A.
Back in 2003-04 when I was putting my 'Cuda together I wanted overdrive since I knew I would actually use the car, not just go to a handful of shows, cruises or autocrosses. Back then the Tremec TKO was the only real option. If I were doing it today, I would go with the Passion since it is a true bolt it. The Tremec did require a good deal of tunnel modification in order to get the driveline angles I wanted. On the plus side it has been trouble free and I've got around 50,000 miles on it now. I did break a spring in a McLeod clutch disc once, but the transmission itself hasn't given any trouble. I don't feel comfortable trying no lift, full on power shifts with it like I did with the 833 in my '63 Sport Fury, but I do shift quickly at 6,200 rpm without any problems. The biggest problems I see with it are tunnel fit in some models and the need for an external shift linkage in "E" bodies.
[Re: HoosierTA]
#1957704
11/25/15 03:27 PM
11/25/15 03:27 PM
Posts: 821 On the open road
Hrtbkr
On the open road
I've put 100K+ on mine.
The good: 75mph = 2500 rpm. It's a tough transmission.
The bad: Cutting a hole in your tunnel (although I heard you can bump it out for enough clearance). Everyone I've talked to has had to modify the tunnel. It's a tight fit and hard to install. The driveline angle is a bit off even with the mods. Keeping the pilot bearing in the crankshaft. The aforementioned shifting issues at high rpm.
I would go with the Passon unit if I had to do it over again, or their OD conversion for an 833.
While outside on the turnpike
They got this new hit tune
Where thrills become as cheap as gas
And gas as cheap as thrills
[Re: lewtot184]
#1958121
11/26/15 03:13 AM
11/26/15 03:13 AM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
the only driving experience i have with them is when i've drove my friends 427 vette with the tremec. the only thing i can say is if you have the option such as the passon transmisions, then thats what i'd do. the tremec is ok to drive on but difficult to shift briskly. i have a friend with a tremec in a '68 gtx and last time i talked to him he said he'd like to go back to the 833. That is not what I have understood about the 833 being easier to shift. i know they were a lot harder to shift than the Muncies and Borg Warner 4 speeds. I drove a new Mustang GT in 1967 with a top loader and thought that was pretty good and certainly it was strong. The strongest and hardest shifting I have had to live with was the NP 6 speed in my 2002 CTD and I put a BD shift kit in it to make the throws shorter and that made it harder yet, but it was stout and had to be to live with the torque of the diesel.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Polarapete]
#1958327
11/26/15 01:54 PM
11/26/15 01:54 PM
Posts: 9,066 Eugene, Oregon
minivan
Eugene, Oregon
[quote=lewtot184]
That is not what I have understood about the 833 being easier to shift. i know they were a lot harder to shift than the Muncies and Borg Warner 4 speeds. Its been a long time ago but this is exactly what I remember going from GM vehicles to my 69 super bee A12 car.. That 18 spline was a pig for fast shifting after the Muncie/T10 4 speeds I drove.... On a different topic the Passon 5 speed is probably the best option, but the wait for one could be 2-3 years from what I have seen?? Am I wrong??? At 60 yrs old I could be dead by then....
[Re: HoosierTA]
#1958619
11/27/15 01:26 AM
11/27/15 01:26 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I dunno about the A833 being hard/heavy to shift, I never felt it was but I learned to shift on old school transmissions not modern lightweight stuff. The fresh A833 I put in my 87 Diplomat definately shifted better than any other transmission I ever shifted, including more modern 5 speeds (A525/T5/whatever's in an 05 Neon).
Now a transmission you will never get to shift fast is an NP435.
[Re: Supercuda]
#1958656
11/27/15 03:28 AM
11/27/15 03:28 AM
Posts: 3,310 Walnut Creek, CA
blown340
Walnut Creek, CA
I've had a tremec TKO in my challenger since 2003 with a ton of miles and have no complaints.
-Jon
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah
71 valiant scamp 318/A833OD/AC/PS
00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process
73 W200 Power wagon, PTO winch, 4 spd
[Re: HoosierTA]
#1958861
11/27/15 06:13 PM
11/27/15 06:13 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
FWIW, I went 6-speed. The T56 Magnum is supposed to be the cat's meow with none of the shifting concerns of the 5speeds. It's a TR6060 based trans, which is current Viper, Corvette, Mustang, Challenger, Camaro, etc.
