Tires and rims pro touring 1969? #1954564
11/19/15 10:59 PM
11/19/15 10:59 PM
nebraska
69coronet440 Offline OP
nebraska
Looking to pro tour my 1969 Coronet RT tribute. Was thinking of putting 18 on front with 4 1/2 back spacing and on the rear 20s with 5 3/4 back spacing. I know the front will work but has any body put 20s on the rear without modifiing any of the cars body if so what back spacing are you running. Thanks for your help
Re: Tires and rims pro touring 1969? [Re: 69coronet440] #1954803
11/20/15 11:44 AM
11/20/15 11:44 AM
Sacramento, Ca
Darius Offline
Darius  Offline
Sacramento, Ca
With all the die hard purists on this site I expect you will catch some sheite about those rim sizes!
Driving modern convenience in classic beauty
Re: Tires and rims pro touring 1969? [Re: 69coronet440] #1954890
11/20/15 03:05 PM
11/20/15 03:05 PM
AndyF Offline
AndyF  Offline
Use one of your existing wheels and measure from there. If you have a 15 inch wheel then add 2.5 inches on to the rim and spin it in the wheel well. You can figure it out by using a tape measure and some simple math.
