Re: 69 Dart fan motor removal?
[Re: justinp61]
#195449
01/16/09 07:41 PM
01/16/09 07:41 PM
Posts: 1,675 Mi.
G-Money1320
Mi.
You need to remove the heater box from the dash as the motor is attatched to it. The nuts inside the engine compartment you are seeing hold the heater box to the fire wall. Dont forget the plate between the heater hoses also and the small bolt attatched inside the vent to a lever hooked at the top of the vent in the cowl area..
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out. 11.06 open headers----so far!!
