I know you said leave weight distribution out for the moment, but it is a big part of the input I can offer.
I think a 100 to 108 inch chassis would work well, allowing good weight transfer.
Since traction will be very poor, rear weight percentage becomes VERY important. As an example, going from 50 / 50 distribution in my 106" WB Dart to 53 percent on the front, there was a serious loss of acceleration on my "test" driveway
If I were ever to build a 1,000 hp street car, I would use a similar chassis, and get the rear percentage of weight as high as I could, hopefully as high as 60 percent or more, with a Cg higher than what would be found on a chassis that works well at the track. As a safety measure, I might equip the car with some rather short (not sticking out from under the car) wheelie bars, just for safeties sake.
