Re: Gen 3, and aftermarket ignition coils
[Re: 1970Dart3406]
#1948994
11/10/15 08:41 PM
11/10/15 08:41 PM
Posts: 491 South Dakota
kilo1
South Dakota
No need test have shown the MSD and other coils actually don't work as well as stock
USMC 1982-1988 GM Parts 1988 -2006 US Army 2006-2015
[Re: 1970Dart3406]
#1949425
11/11/15 03:32 PM
11/11/15 03:32 PM
Posts: 10,015 Frostbitefalls MN (Rocky&Bullw...
gregsdart
By reducing the plug gap, the coils can handle a lot more cylinder pressure. Every little miss fire on a factory engine causes emissions they have to clean up, plus a touch of lost mileage. With that in mind, I bet they are as good as my 4.6 Mustang coils, and with tighter gaps those coils have handled a lot of boost. I run 7.5 PSI with the gap at .035, have for 50,000 hard miles.
[Re: 1970Dart3406]
#1949438
11/11/15 03:51 PM
11/11/15 03:51 PM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
I have never seen a stock hemi coil go bad, tons o ford coils go bad. I also don't see how you can improve on something proven to work so well.
[Re: dogdays]
#1954287
11/19/15 02:27 PM
11/19/15 02:27 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
One thing to remember is a single-cylinder coil has one or two engine revolutions to charge up between spark events.
R. And they run cooler than a coil sparking 4 times per revolution.
[Re: 1970Dart3406]
#1958699
11/27/15 11:09 AM
11/27/15 11:09 AM
Posts: 361 Canada
onig
Canada
I THINK Firecore had some in testing mode. They gave an extra 5 HP on the dyno that they were tested on. This was years ago, not sure what happened, or if they made it into production.
69 Dart
[Re: 1970Dart3406]
#1960060
11/30/15 01:22 AM
11/30/15 01:22 AM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
Actually, the new ones are 73% hotter. Mancini should still have some in stock. We have them on some Super Stockers. You can open that gap back up...
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
[Re: sunroofgtx]
#1961510
12/02/15 03:09 AM
12/02/15 03:09 AM
Posts: 259 Scatchamatoon
Saskabusa
Scatchamatoon
Is there a difference between 5.7 and 6.1 coils?
1974 Roadrunner
1967 Charger
[Re: Saskabusa]
#1961951
12/02/15 07:32 PM
12/02/15 07:32 PM
kilo1
South Dakota
Is there a difference between 5.7 and 6.1 coils? No same coil.
[Re: 1970Dart3406]
#2023219
03/02/16 03:42 PM
03/02/16 03:42 PM
sunroofgtx
Cleveland
Same coil and part number.. Give us a call. Thanks
