Skinny front radials, part 2
#1951903
11/15/15 09:34 PM
11/15/15 09:34 PM
Posts: 17,924 Akron, Ohio
ProSport
Akron, Ohio
I'm having a terrible time deciding which tire to buy, only because I want the TALLEST one and with all the weird actual numbers you hear about with these front radial tires it's hard to decide. I have a 15x4" wheel and I have a Duster so I have to stick with a 26" tire, I run a 275/60/15 radial on the back. My Sportsman front tires only measure 80" in circumference, I'd love to find something that truly is 81" or slightly bigger. I could take a tape measure to Summit and check out all 3 tires but they won't be mounted so the measurements may be useless.? Info I've gathered so far........ Hoosier #19050 is 80.5" circumference, $204 each and are in stock at Summit. I'd love to measure a mounted set of these to see what the actual circumference is. http://www.summitracing.com/parts/hoo-19050M&H #ROD02 is 81.7" circumference, $182 each and are in stock at Summit. To me the tread kinda looks like a dirt track tread but I've heard people say they look good like a drag tire. http://www.summitracing.com/parts/mnh-rod02M/T #6652 is advertised as 81.6" circumference but I'm doubting that since everyone says they're about 25.25" tall and that's how tall my Sportsmans are, and they are only 80" in circumference. They are in stock at Summit and cost $188.73 each. http://www.summitracing.com/oh/parts/mtt-6652Do any of you guys own any of these tires?
Re: Skinny front radials, part 2
[Re: fbs63]
#1951940
11/15/15 10:18 PM
11/15/15 10:18 PM
ProSport
Akron, Ohio
Bob, My son has a set of the MTs on 4"wheels. I can measure them and post some pics but not till tomorrow evening. That would be much appreciated!
[Re: RV2]
#1951943
11/15/15 10:21 PM
11/15/15 10:21 PM
ProSport
Akron, Ohio
That M&H is 173.99 at jegs Thanks
[Re: RV2]
#1951972
11/15/15 10:57 PM
11/15/15 10:57 PM
ProSport
Akron, Ohio
I like the M&H, I might do those with the 4" steel wheels on my Valiant When I was googling, I saw a couple guys mention that the M&H tires drove really nice on the street. My 26" M/T Sportsmans are awful, they are like a motorcycle tire and try to follow every little crack in the road.
[Re: ProSport]
#1952196
11/16/15 09:46 AM
11/16/15 09:46 AM
Posts: 1,629 pa
572charger
pa
did u ck a 205 75 15 radial tire thats what ive been using for many years i get them at pep boys for 70 bucks each !!!
606 hemi pump gas best 9.60 at 142mph on motor 05 hemi daytona 1500 go-mango 4wd quadcab 2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
[Re: ProSport]
#1952200
11/16/15 09:56 AM
11/16/15 09:56 AM
ProSport
Akron, Ohio
That's the size I bought and mounted, they were ginormous on a Duster, wouldn't even fit on the car, they hit fenders when turning. They were Cooper brand. They were listed as 26.98 tall and that's what they measured.
[Re: ProSport]
#1952227
11/16/15 11:21 AM
11/16/15 11:21 AM
ProSport
Akron, Ohio
The 205/70/15 is 26.28" tall so it might fit better, I just don't think the 8.11" section width will look good on a 4" rim. I do not race this car but I like the looks of skinny front tire. http://m.summitracing.com/parts/coo-34012
[Re: moparx]
#1952240
11/16/15 11:45 AM
11/16/15 11:45 AM
ProSport
Akron, Ohio
how about a 195 75 tire ? i can't help with the measurements though. sorry. I would bet the 195 is a little too tall to fit a Duster but I wouldn't know for sure til I measured one mounted. Plus they are $146 and up so I may as well get one of the 3 I mentioned in the first post of this thread. It's worth looking into though, thanks.
[Re: ProSport]
#1952471
11/16/15 07:08 PM
11/16/15 07:08 PM
Posts: 2,299 NE Ohio
DoubleD
NE Ohio
it's a street car - why run a skinny up front? go to a wider rim and put some wider tires up front - it will handle much better and be a bunch safer stopping
[Re: fbs63]
#1952481
11/16/15 07:34 PM
11/16/15 07:34 PM
ProSport
Akron, Ohio
Bob, The MT's measure 25 1/2" tall an the circumference is approximately 80 1/2" on the 4" rim. He has a 69 Barracuda and they look good. Hope this helps Thanks! I'm glad to hear they're not shorter than my sportsmans, they're actually a tad taller.
[Re: DoubleD]
#1952484
11/16/15 07:38 PM
11/16/15 07:38 PM
ProSport
Akron, Ohio
it's a street car - why run a skinny up front? go to a wider rim and put some wider tires up front - it will handle much better and be a bunch safer stopping Dave it's just my preference for looks. My next build is gonna be a pro-touring car with 4 fat tires and a 5 speed.
[Re: ProSport]
#1952815
11/17/15 08:50 AM
11/17/15 08:50 AM
ProSport
Akron, Ohio
Ron, how wide is your front rim? Mine is only 4". Those tires do look good.
