How to remove dowel pins? #195206
01/16/09 02:46 PM
01/16/09 02:46 PM
Sweden
6pakdude Offline OP
6pakdude  Offline OP
Sweden
I'm decking my org 440 block to get the comp ratio I want.
Need to remove the dowel pins for the 906 heads.
How do you get them out?
Peter
Re: How to remove dowel pins? [Re: 6pakdude] #195207
01/16/09 02:56 PM
01/16/09 02:56 PM
AndyF Offline
AndyF  Offline
Best way is to use a dowel pin puller.
Re: How to remove dowel pins? [Re: AndyF] #195208
01/16/09 03:40 PM
01/16/09 03:40 PM
Sweden
6pakdude Offline OP
6pakdude  Offline OP
Sweden
Can somebody explain how that tool is working.
or how you do it without the special tool.
Re: How to remove dowel pins? [Re: 6pakdude] #195209
01/16/09 04:52 PM
01/16/09 04:52 PM
BRawls Offline
super gas
BRawls  Offline
super gas
Shop doing the work should pull them for you as part of the service when they deck the block. With the right tool, it's a 5 second job.
Re: How to remove dowel pins? [Re: 6pakdude] #195210
01/16/09 05:34 PM
01/16/09 05:34 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I've taken them out with vise grips on very tight, twist and pull out no problems. When I did it, I applied a bit of heat on the block near thebase just in case they would be stubborn, but they really weren't.
If you're taking it to a machine shop for work, I'd let them do it as already suggested.
