Re: question on 69 big block a-body plug wires.
[Re: BlueRacer69]
#1952401
11/16/15 04:52 PM
11/16/15 04:52 PM
Posts: 43,828 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Here are some pics from the GTS Registry about plug wire routing and the proper holders. The valve covers are not original in the pics, they are the Direct Connection tall covers. I do have a few original covers and will take a pic so you can match-up yours.
JB Rhinehart, Realist
A-Body's RULE!
[Re: BlueRacer69]
#1952421
11/16/15 05:38 PM
11/16/15 05:38 PM
Posts: 606 Mass
charge70
Mass
Thanks Rhino, waiting to hear back from you. So I guess I have a wrong driver side valve cover then. The one I have has no wire holders attached to it for a wire to run along the top if it. Are the 383 and 440 Dart`s plug wires run the same way? Yes,the wires run the same way 383 or 440.I used a c-body d/s valve cover when I restored my dart.Sounds like you have a b-body cover now. John.
1970 Dodge Charger R/T S.E.
1969 Dodge Dart GTS 440 M-Code
1970 Dodge Charger 500 383/4-speed w/A.C.
[Re: charge70]
#1952496
11/16/15 08:15 PM
11/16/15 08:15 PM
Posts: 737 Michigan
BlueRacer69
Thanks Rhino, waiting to hear back from you. So I guess I have a wrong driver side valve cover then. The one I have has no wire holders attached to it for a wire to run along the top if it. Are the 383 and 440 Dart`s plug wires run the same way? Yes,the wires run the same way 383 or 440.I used a c-body d/s valve cover when I restored my dart.Sounds like you have a b-body cover now. John. I think your right charge70, it must be off a B-body car. It looks right except it does not have any plug wire holders. I have some single odd & end valve covers kicking around, I`ll have to look around and see if I can find the proper one. Now what do I do about a #7 plug wire? Any suggestions. I was getting ready to order one of those date coded set, but I'm guessing #7 wire will be to short now.
[Re: BlueRacer69]
#1952602
11/16/15 10:54 PM
11/16/15 10:54 PM
Posts: 606 Mass
charge70
Mass
Thanks Rhino, waiting to hear back from you. So I guess I have a wrong driver side valve cover then. The one I have has no wire holders attached to it for a wire to run along the top if it. Are the 383 and 440 Dart`s plug wires run the same way? Yes,the wires run the same way 383 or 440.I used a c-body d/s valve cover when I restored my dart.Sounds like you have a b-body cover now. John. I think your right charge70, it must be off a B-body car. It looks right except it does not have any plug wire holders. I have some single odd & end valve covers kicking around, I`ll have to look around and see if I can find the proper one. Now what do I do about a #7 plug wire? Any suggestions. I was getting ready to order one of those date coded set, but I'm guessing #7 wire will be to short now. Google "Herbs Parts" he has a-body big block wire sets in various date codes.
[Re: BlueRacer69]
#1957677
11/25/15 02:20 PM
11/25/15 02:20 PM
Posts: 75,274 A gulag near you.
JohnRR
A gulag near you.
Thanks Rhino, waiting to hear back from you. So I guess I have a wrong driver side valve cover then. The one I have has no wire holders attached to it for a wire to run along the top if it. Are the 383 and 440 Dart`s plug wires run the same way? Yes the 383 and 440 wires run the same , the left valve cover is the same as the Left cover for lo po 383,440 all platforms and HP 383/440 in a C Body. 383 had chrome covers , 440 I'm 99% sure painted covers .
Mainstream Media is the new Pravda
[Re: JohnRR]
#1963641
12/05/15 11:26 AM
12/05/15 11:26 AM
Posts: 10,931 North Dakota
6PakBee
North Dakota
JohnRR, thanks for the link. How do you dig up these guys? That is a good site that I've never heard of.
[Re: 6PakBee]
#1967268
12/10/15 07:05 PM
12/10/15 07:05 PM
JohnRR
A gulag near you.
JohnRR, thanks for the link. How do you dig up these guys? That is a good site that I've never heard of. I've been putting that link up for at least a decade , they have been around for a long time .
