70 Cuda Gas Tank Vent System ? #195185
01/16/09 01:10 PM
01/16/09 01:10 PM
Georgetown Ontario Canada
anlauto Offline OP
anlauto  Offline OP
Anybody have pictures of the gas tank vent system for a 70 Cuda. I bought the kit from Fine Lines but have no idea how it mounts.
A shot from the underside would be good as well
Re: 70 Cuda Gas Tank Vent System ? [Re: anlauto] #195186
01/16/09 01:30 PM
01/16/09 01:30 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Federal or California?
Re: 70 Cuda Gas Tank Vent System ? [Re: Snoopy] #195187
01/16/09 03:20 PM
01/16/09 03:20 PM
anlauto Offline OP
anlauto  Offline OP
I'm going to say the more common one...So I'll choose Federal
CHECK OUT MY NEW WEB SITE !
Re: 70 Cuda Gas Tank Vent System ? [Re: Snoopy] #195188
01/17/09 11:56 AM
01/17/09 11:56 AM
anlauto Offline OP
anlauto  Offline OP
Re: 70 Cuda Gas Tank Vent System ? [Re: anlauto] #195189
01/19/09 01:44 PM
01/19/09 01:44 PM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
Allan,
Let me guess, you're good with the rubber line to the nipple and the problem is you don't know where the other end goes after it goes up through the trunk and back out?
Let it hang in the slot in the frame rail. The other thing you're going to need is the impossible to find clip that holds the double tube to the outside of the pinch weld of the wheel house to keep it tight in the trunk.
Re: 70 Cuda Gas Tank Vent System ? [Re: HEMICUDA] #195190
01/19/09 01:55 PM
01/19/09 01:55 PM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
Here's a picture of the clip that I haven't told anyone about that we did.
Re: 70 Cuda Gas Tank Vent System ? [Re: HEMICUDA] #195191
01/19/09 02:29 PM
01/19/09 02:29 PM
anlauto Offline OP
anlauto  Offline OP
So...A rubber hose runs from the gas tank...through the frame and connects to one end the the tube that enters the trunk. The other tube coming from inside the trunk connects to the "S" shaped tube, and that just rests inside the frame rail?
Re: 70 Cuda Gas Tank Vent System ? [Re: anlauto] #195192
01/19/09 03:00 PM
01/19/09 03:00 PM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
You're only connecting one tube to the tank with the "S" line in between with short rubber hose on either ends. The bigger of the two lines just vents into the frame rail, it doesn't connect to anything.
Re: 70 Cuda Gas Tank Vent System ? [Re: HEMICUDA] #195193
01/19/09 03:01 PM
01/19/09 03:01 PM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
#2
Re: 70 Cuda Gas Tank Vent System ? [Re: anlauto] #195194
01/19/09 05:25 PM
01/19/09 05:25 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
no, gas tank to short rubber hose (4" max) to the S tube that goes thru the frame rail to short rubber hose to tube in trunk. bottom of tube coming out of trunk goes into frame rail and is just open
Re: 70 Cuda Gas Tank Vent System ? [Re: HEMICUDA] #195195
01/19/09 08:24 PM
01/19/09 08:24 PM
middle of the country
aar1 Offline
aar1  Offline
Mike,
Does that mean you just did ONE clip or are you saying you carry those now but it's a secret?
Re: 70 Cuda Gas Tank Vent System ? [Re: aar1] #195196
01/20/09 06:40 AM
01/20/09 06:40 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
I wasn't going to say anything until I have a good quantity in my hands. I have, maybe, 4 more here until I get production stock in a week or so.
With my limited knowledge of cars, that's the only place that clip is used and the first thing to gets lost on a 70 Cuda/Barracuda hard top. Besides, I needed 3 for my own cars.
I'm not sure the market is there for the volumn that had to be made, but that's ok, I personally needed them.
Re: 70 Cuda Gas Tank Vent System ? [Re: HEMICUDA] #195197
01/21/09 07:07 AM
01/21/09 07:07 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Here's a previous thread with some more pics.. 70 vent line
Re: 70 Cuda Gas Tank Vent System ? [Re: screamindriver] #195198
01/21/09 07:20 AM
01/21/09 07:20 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
Hey Colin, I went through that old post and I noticed the vent line going through the whole in the metal of the trunk floor. Was it replaced? I looked at 2 of my 70 Cudas here at the shop and neither one has the stamping anywhere near where the line goes, it's to far back. Looking at your's, that's the only place it could go to get a straight shot to the "S" line.
Re: 70 Cuda Gas Tank Vent System ? [Re: HEMICUDA] #195199
01/21/09 07:31 AM
01/21/09 07:31 AM
Harrisburg, Pa.
Harrisburg, Pa.
Hi Mike.. Yes the trunk floor was replaced..A look at those tabs revealed they're not radiused like the originals..This is the only one I've seen with the line routing like that also..A nice addition to help hold the line in place but probably not correct... Glad to see that line clip is being repoped...
