Re: Driveshaft angle of the dangle
[Re: Hooligan]
#1951542
11/15/15 12:40 PM
11/15/15 12:40 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Tangentially I suppose it might be relevant. But drive shaft angles are important regardless of application, street only, drag race, off road, etc. Unless you rotated the housing or changed the location of the tail shaft it's not likely to have changed but you can check it easy enough. Here's a calculator that does the math for you, you do have to measure the angles though. I have a fancy digital protractor that measures to the tenth of a degree. http://spicerparts.com/calculators/driveline-operating-angle-calculatorHow to measure, cause someone will ask http://www.hotrodhotline.com/md/html/drive_shaft_harmonics.php
