Re: Charging Problem - Stumped!
[Re: TooMany62s]
#1951478
11/15/15 10:37 AM
11/15/15 10:37 AM
Posts: 1,796 Greer, SC
TooMany62s
Greer, SC
I'm not too concerned about stock appearance. I have checked the voltage with two meters. They show within .1v of each other.
[Re: TooMany62s]
#1951509
11/15/15 11:52 AM
11/15/15 11:52 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
How about putting a real ammeter in the circuit to see if your factory gauge is reading wrong.
Factory ammeters do not have numbers on them for a reason, they are not accurate, all they will tell you accurately is if you have current or do not have current going thru them, trying to extrapolate any kind of value beyond that is futile.
BTW, did you also make sure you had a good ground path to the alternator and regulator, both sides of the circuit have to be good.
[Re: TooMany62s]
#1951582
11/15/15 01:28 PM
11/15/15 01:28 PM
RapidRobert
I would seperate the bulkhead and clean the male/female terminals in both halves. I'm assuming the reg is an electronic version (most replacement ones are nowadays & if no wire wound resistors on the bottom side then it is an electronic one) & that it ain't the blue constant voltage blue reg. Jump from the batt positive post or starter relay battery post directly to the "ign" terminal on the reg. I'm assuming with your jumpering so far that the eng/reg/alt have good ground path continuity back to the batt neg post. We're the best! we'll figure it out in short order for you. You are SURE you have a good (non sulphated) batt in there? I'm thinking yes but I had to ask & the symptom (amp needle behavior) sure sounds like classic bad electromechanical reg but for it to get worse after you eliminated the voltage drops & got the charging rate back to normal ain't making sense. & the needle staying way further to the right started right after you did the mods correct? I'm not thinking a fubared field circuit path in the alt could be doing this so if the batt is good and the reg is good then it has to be a wiring (positive side) continuity issue or a ground path (negative side) continuity issue. Short version: at a fast idle what are the voltages at the (1) batt posts (2) reg "ign" terminal to batt neg post and (4) how much voltage drop on low scale (20V) from alt case to batt neg post and (5) voltage drop from reg case to batt neg post and (6) from "grn" terminal on reg to field terminal on the alt
[Re: TooMany62s]
#1951583
11/15/15 01:29 PM
11/15/15 01:29 PM
Andrewh
amps don't just magically appear.
high voltage is a problem because it can damage equipment and wiring.
high amps means something is drawing that power. you cannot push 20 amps to an item, only the voltage/charge to it. it has to consume 20 amps to pull 20 amps.
So either way, as long as your voltage is good, I would say you are not "over charging" anything.
But, that amp gauge is a known failure point. So is the bulkhead connector for charging. IF one of those items has high resistance due to going bad, or corrosion, you may be heating something up, drawing those 20 amps.
The mad electrical bypass is what I would do next and then call it good.
BUT if you really want to trouble shoot it, rent or buy an amp meter clamp on style and see how much you are actually pulling. or get a modern amp meter style gauge and see what it says.
[Re: TooMany62s]
#1951883
11/15/15 09:11 PM
11/15/15 09:11 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
I'm not too concerned about stock appearance. I'm happy to see this sentence. Do yourself a huge favor, get a Denso alternator from a Toyota car or whatever, run the 2 wires that it requires, and never worry about charging problems again, it's the best thing I ever did to my big block Duster. AR-Engineering has brackets and a pigtail for this.
[Re: TooMany62s]
#1952269
11/16/15 01:09 PM
11/16/15 01:09 PM
RapidRobert
Definitely solve the problem at hand first as you alluded to. it will fix the issue/increase your knowledge/experience/give you confidence in your abilities. Just me I like the ammeter so I do Nachos bulkhead parallel bypass to elim that weak area & clean ALL terminals/connections & I add a voltmeter to switched 12V. The Madd info is good if you dont mind loseing the ammeter function & I see the bulkhead as the problem not the ammeter itself & I strive to keep its' needle close to 12 0'clock & a person can relay the headlights/ac/heater directly to the alt. I hear the Denso is a good swap, does it use the same reg system as ours' does I'm wondering
[Re: TooMany62s]
#1952282
11/16/15 01:24 PM
11/16/15 01:24 PM
ProSport
Akron, Ohio
Denso is a 2 wire hookup, run 2 new wires and bypass all your problems and go cruisin. Mine is always at 14 volts. And it's internally regulated. My denso was about $59 total on ebay. I have the part number at home. I just use a voltmeter, no ammeter.
