Re: 63 Chrysler 383
[Re: Myth300]
#1951301
11/15/15 12:12 AM
11/15/15 12:12 AM
RapidRobert
Welcome aboard! Summitt has close to OE specs cams for cheap (I have one). Many have used em with no complaints. $72 & if you add in a bit more to your list the shipping is free over $100 (& you'll need lifters/tchain (get a 3 way) & file fit plasma moly rings
Re: 63 Chrysler 383
[Re: Myth300]
#1951356
11/15/15 01:11 AM
11/15/15 01:11 AM
Posts: 21,088 Niles , Ohio
therocks
Niles , Ohio
I agree the Summit cam kits work good.Ive run all of them for Mopars and some Chevys also.Ran the big cam in my 440 and then stuck it in a 62 383.It ran great in it but it had 3.91 gears.Id say it would still run decent but for close to factory go small.Rocky
Chrysler Firepower
Re: 63 Chrysler 383
[Re: Myth300]
#1951357
11/15/15 01:13 AM
11/15/15 01:13 AM
RapidRobert
On second thought the Summitt SB tchain we bought for the stock car way back (house brand) had way more slack than I was comfortable with. I dont have the final word on at what point the out of round and taper says that cast rings would be better (see what others say & you need good measurements for us) & a dial bore gauge would be the best/fastest but a person can come close with a ring with squared edges and measureing gap at top and bottom of ring travel then again at 90 deg to that (top and bottom). Just me (some dont care for it) I would final finish with a dingle berry hone of the right grit especially for a rering
Re: 63 Chrysler 383
[Re: Myth300]
#1951518
11/15/15 12:11 PM
11/15/15 12:11 PM
Posts: 19,682 north of coder
moparx
.020 is a HUGE amount to be out of round in bore size, and a 3 stone deglazeing hone will not make make it seal in any way possible. are you sure you are measuring correctly ? calipers are not the measuring device to be using here. i'm not trying to be a smart a$z, just 42 years as a machinist talking. FSM for 63 states .005 out of round max and .010 taper top to bottom before re boring is necessary. i hope your stated number was just a typo. forgot to add the standard bore size for the 383 is 4.2495-4.2515
Re: 63 Chrysler 383
[Re: Myth300]
#1951955
11/15/15 10:39 PM
11/15/15 10:39 PM
Posts: 11 NY
Myth300
NY
Ya was a typo sorry they are 4.252( 2 cyilders) at most lol sorry about that most is 4.250 was late when I made that last post sorry and telescoping gauge is what I used could afford a bore Gage
Re: 63 Chrysler 383
[Re: Myth300]
#1952578
11/16/15 10:15 PM
11/16/15 10:15 PM
RapidRobert
Moly rings are far better than cast iron but reportedly if the out of round and or taper is on the edge that CI might seal better (no opinion on that) & if it is worn to that point what about reboring/new pistons/rings etc. But I think I would still go with Moly either way rering or rebore (& what Dog said, a Moly ring set is a moly top ring and a castiron 2nd ring) tho there are specialized apps with top/bottom Moly rings but not commonly used) and what he said Moly is a far better ring type for most apps. just me unless it was a numbers matching deal I'd get a 400 block and offsett grind a 440 steel crank for 470 cubes. the external dimentions would be the same so all your brackets/exhaust etc would right back up. You might peruse Andys' 451 manifesto in the archives. It might persuade you!
