Re: Shaker Adapter Ring Nuts [Re: mopar4ya] #1952389
11/16/15 04:24 PM
11/16/15 04:24 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
The Bass Boat! laugh2
Re: Shaker Adapter Ring Nuts [Re: mccannix] #1952636
11/16/15 11:37 PM
11/16/15 11:37 PM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
Originally Posted By mccannix
Since you have the seldom seen adapter ring with the nuts welded on top, they take the larger thread bolt ( your style shown on right, smaller thread more common underside nut on left ).
I went to do some measuring of mine tonight and realize mine has the smaller 10-24 machine screw thread. It does measure .500 square and between .156-.166 tall, just depends on which one you measure. I'm having no luck finding a piloted weld nut with this big of a square. Don't want to try and make them, it would be almost impossible to duplicate. I also took a picture of the bolts that were in my bubble, can anyone tell me if these are correct.
Dan.
Re: Shaker Adapter Ring Nuts [Re: mopar4ya] #1952768
11/17/15 02:20 AM
11/17/15 02:20 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
In that case you need these 10-24 black phosphate bolts with captive washer and anchor on the head.
Check ebay as they pop up for sale all the time.
Re: Shaker Adapter Ring Nuts [Re: mccannix] #1953309
11/17/15 10:55 PM
11/17/15 10:55 PM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
Thanks! Are these bolts still available from a suppler today?. Or do I need to look for good used ones.
Dan.
Re: Shaker Adapter Ring Nuts [Re: mopar4ya] #1953454
11/18/15 01:50 AM
11/18/15 01:50 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Dan....pm sent
Re: Shaker Adapter Ring Nuts [Re: mopar4ya] #1954032
11/19/15 12:13 AM
11/19/15 12:13 AM
Ohio
C_B5 Offline
C_B5  Offline
Ohio
Terry,
Guess I never realized how much interest there was in the adapter rings with the nuts incorrectly welded on the top.
In retrospect maybe I shouldn't have had you fix my NOS one that originally had the nuts welded on top all those years ago !
