340 Rebuild - lifter bore issue
#1948770
11/10/15 03:19 PM
11/10/15 03:19 PM
340clone
Rebuilding a (stock) 340 for my '71 Challenger. I noticed that two of the lifter bores have a bit of slack when fitting new lifters. I don't have a measurement yet, but lifter can rock back and fourth ever so slightly in bore. Can I let this slide or do I need to have them sleeved?
Re: 340 Rebuild - lifter bore issue
[Re: 340clone]
#1948794
11/10/15 03:42 PM
11/10/15 03:42 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Was the engine running prior to the rebuild? Measure them. If the lifter to bore clearance is greater than .002 I'd look into having them bushed. You also might want to measure the lifters to make sure you don't have any of them on the small side. If you are using a modern grind cam and something with a little pop to it, that lifter to cam lobe orientation is very important. If this is a stockish type build it's probably not a big deal.
[Re: moper]
#1948800
11/10/15 03:50 PM
11/10/15 03:50 PM
RapidRobert
that does not sound good. What Moper said, get a carefull measurement & post what it is
[Re: 340clone]
#1949063
11/10/15 10:42 PM
11/10/15 10:42 PM
moper
Columbia, CT
They used to have oversize lifters. Not sure if they still do but that would be a choice too.
[Re: 340clone]
#1949683
11/11/15 11:12 PM
11/11/15 11:12 PM
RapidRobert
the the other bores are perfect, You might measure all of em while you're at it
[Re: 340clone]
#1949986
11/12/15 02:55 PM
11/12/15 02:55 PM
moper
Columbia, CT
Well, if you're keeping it stck, and keeping the cam smaller, it's probably not a big deal at all. If you start looking at more power and want a faster lift rate (Hughes, Comp XE, Lunati VooDoo, etc) then you may get into trouble without addressing the loose bores. But an older conservative grind (stock or slightly more than stock but an older lobe design) probably won;t cause problems.
