Timing chain #1948123
11/09/15 04:09 PM
11/09/15 04:09 PM
Renton Washington
Triple Threat Offline OP
Renton Washington
What timing chain is everyone using on their builds? I've read some negative things about the factory 5.7 chains.
Manley, Comp, Howards and likely some others all make them...
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Timing chain [Re: Triple Threat] #1948156
11/09/15 05:27 PM
11/09/15 05:27 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
I asked this question before and the 5.7 had problems if they had automatics and MDS.
I have also read that the Manley chain is made in India. Not sure about the Howards chain though havent called them lately.
I use the stock chain
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Timing chain [Re: RylisPro] #1948157
11/09/15 05:31 PM
11/09/15 05:31 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Using the Manley chain with no problems...over 1200 3/8 mile laps on the dirt tracks.
If you like drag racing, support your local track.
Re: Timing chain [Re: Triple Threat] #1948200
11/09/15 06:46 PM
11/09/15 06:46 PM
USA
hudsonhornet7x Offline
USA
Any engine that has VVT uses the same chain. No aftermarket that I am aware of. The 5.7 with MDS and VVT caused some wierd harmonics that broke the chains. That has now been fixed. To illustrate the point, the Hellcat uses the same chain with no issues at all.
Re: Timing chain [Re: Triple Threat] #1948224
11/09/15 07:29 PM
11/09/15 07:29 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
I used a factory 6.1 timing set on mine. Simply because there isn't another US made option. I've overseen over 20 engine builds on these motors, and all used a factory 6.1 timing set. Never an issue.
The only internal parts of my engine that are even aftermarket are the cam, bearings and valve springs. And those are all domestic.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Timing chain [Re: AlexP] #1948375
11/09/15 10:05 PM
11/09/15 10:05 PM
Deland, Florida
biff426 Offline
biff426  Offline
Deland, Florida
I would stay away from the manley I had issues that they were aware of but don't put in the instructions. The issue is the cam snout,timing gear thrust plate clearance you should check this with all after market cams BTW
Re: Timing chain [Re: Triple Threat] #1948447
11/10/15 12:02 AM
11/10/15 12:02 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
For $100-140, stock 6.1 all day long.
Mopar to the bone!!!
Re: Timing chain [Re: Triple Threat] #1948521
11/10/15 01:40 AM
11/10/15 01:40 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
The problem with the 5.7 chain is the chain tensioner. Get the whole stock 6.1 setup.
