Re: Anyone here running MT Pro Bracket Radials ? [Re: TheOtherDodge] #1947640
11/08/15 06:57 PM
11/08/15 06:57 PM
Sydney,Australia
tex013 Online content OP
tex013  Online Content OP
Sydney,Australia
Originally Posted By TheOtherDodge
I have been thinking about this tire, but not being "street legal", I am wary about driving it around.
I currently run the 315 ET DR on a 12" rim. And the rim size would be my concern on the 10.5 PRO.
Here are the comparisons:
Tire..............Style......Compound..Height..Section..Tread..Weight
315x60x15..ET DR.....R2..............30........12.9......11.9....39
29.5x10.5....PRO.......X5...............30........12.7......10.2....33
Thoughts?
The pro Bracket Radial is a full slick , no grooves at all .
I understand the use of a 12" rim is common . I would suggest asking Jason Moulon on Yellowbullet . He is the MT rep and has been very helpful to me .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Anyone here running MT Pro Bracket Radials ? [Re: tex013] #1947909
11/09/15 03:11 AM
11/09/15 03:11 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
If you are asking if your 12" wheel is too wide.......the answer is NO. Most of the drag radial "hitters" run that tire AND the 315 on 14" wheels, so the 12s will be just fine. That's what we run, but only because 14s won't fit under the car
Re: Anyone here running MT Pro Bracket Radials ? [Re: Monte_Smith] #1949463
11/11/15 04:33 PM
11/11/15 04:33 PM
MN
DUSTER1 Offline
DUSTER1  Offline
MN
I have a set of the Pro's for sale with 12 passes on them for real cheap if anyone is interested. 31.25-12.2R15W
Text me at 218-689-2586
Re: Anyone here running MT Pro Bracket Radials ? [Re: tex013] #1949657
11/11/15 10:29 PM
11/11/15 10:29 PM
Barboursville, VA
belvedere383 Offline
Barboursville, VA
I run the 275-60-15 Pro Drag radial on my car, it should fit that 8in rim with a little bulge.
I run them on 15x10, with 22 psi in them i have been a 1.42 60ft, best et so far of 6.52.
Just something else to think about, plus they are much cheaper around $228.00 a tire.
65' Belvedere
496'' Stroker
Indy Heads
Re: Anyone here running MT Pro Bracket Radials ? [Re: belvedere383] #1949690
11/11/15 11:28 PM
11/11/15 11:28 PM
Sydney,Australia
Sydney,Australia
Belvedere ,
I tried the 275 Pro . Terrible balance issues .
Tex
New best MPH 130.32
Re: Anyone here running MT Pro Bracket Radials ? [Re: tex013] #1949744
11/12/15 01:11 AM
11/12/15 01:11 AM
Tulsa, Ok
WadeMetzinger Offline
Tulsa, Ok
I've been running the standard 28/10.5 on my wife's barracuda with great results but I'm thinking about trying the 28/10.5 bracket radials this year. The MT rep said I will be very happy with them and are way more forgiving than the traditional radial slicks.
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: Anyone here running MT Pro Bracket Radials ? [Re: tex013] #1949883
11/12/15 11:23 AM
11/12/15 11:23 AM
an8sec70cuda Offline
Originally Posted By tex013
Belvedere ,
Tex
I had the same issue. The 275 Pros shook bad on the street like they were out of balance something terrible. Didn't notice it at the track. They are a good working tire, but I've never had a problem like that w/ any other tires and I never balance my rears.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Anyone here running MT Pro Bracket Radials ? [Re: an8sec70cuda] #1949920
11/12/15 12:48 PM
11/12/15 12:48 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Belvedere ,
Tex
I am on my second set of 275 pro's and haven't had a vibration issue. I also like you don't balance my rear tires. Never shakes at track or street driving.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Anyone here running MT Pro Bracket Radials ? [Re: WadeMetzinger] #1949961
11/12/15 01:52 PM
11/12/15 01:52 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
The bracket radials are more forgiving on a marginal track and have a longer life.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Anyone here running MT Pro Bracket Radials ? [Re: tex013] #1950075
11/12/15 06:14 PM
11/12/15 06:14 PM
Barboursville, VA
Barboursville, VA
Yea I do not balance my rears either, I haven't driven much on the street maybe 100 miles or so but no shaking at the track.
Good to know though in case something ever comes up.
65' Belvedere
496'' Stroker
Indy Heads
Re: Anyone here running MT Pro Bracket Radials ? [Re: tex013] #1950097
11/12/15 06:48 PM
11/12/15 06:48 PM
Sydney,Australia
Sydney,Australia
they were so bad , pro 275, I thought something was coming off the car - probably a wheel .like you I never balancing the rears . the pro275 needed something close to 200grams to get close . MT were good and took them back as faulty . with the pro bracket I barely have 28 grams to balance ( 1 ounce). I only balanced these to get a comparison . have never balanced or checked the hoosier radial .
hoosiers are very forgiving , I hope I can get a bit more life with the MT though . also hoping the new 10" rim I ordered will help the lifespan
hey belvedere do you have the stock rear width differential under your 65 ? tubbed ? what backspace rim ?
Tex
New best MPH 130.32
Re: Anyone here running MT Pro Bracket Radials ? [Re: tex013] #1950282
11/13/15 12:52 AM
11/13/15 12:52 AM
Barboursville, VA
Barboursville, VA
My car is mini tubbed with a strange 9in, I believe the rear is 4 in narrower than stock. It also has inboard leaf springs and the wheels are 15x10 weldstars with 4.5 in backspacing.
65' Belvedere
496'' Stroker
Indy Heads
Re: Anyone here running MT Pro Bracket Radials ? [Re: tex013] #1950324
11/13/15 02:36 AM
11/13/15 02:36 AM
Sydney,Australia
Sydney,Australia
thanks
Tex
New best MPH 130.32
Re: Anyone here running MT Pro Bracket Radials ? [Re: tex013] #2658933
05/24/19 11:22 PM
05/24/19 11:22 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I’ve now got about 25 or 30 passes on my 28x9 ProBracket Radials. I’m very happy with the performance. They were worth about a .05 over the ET Drags I was using prior. I’m finding they work best for me down around 18psi. Longevity is still to be seen, but the car has been a copy machine with them thus far.
Re: Anyone here running MT Pro Bracket Radials ? [Re: StealthWedge67] #2658964
05/25/19 06:21 AM
05/25/19 06:21 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have a set with 100 or so passes on them and even some street miles, they look brand new and have worked great. I have only had a few runs with spin on very marginal tracks.
The balance is fantastic on them and i have fought them moving on the rims some. I am going to put some glue on them and see how that holds up.
68 Barracuda Formula S 340
Re: Anyone here running MT Pro Bracket Radials ? [Re: StealthWedge67] #2659082
05/25/19 01:31 PM
05/25/19 01:31 PM
Santa Rosa, Calif
angleiron2 Offline
angleiron2  Offline
Santa Rosa, Calif
I ran both the Pro Bracket Radials 29x 10.5 -15 and the Pro Et Street radials 315x55-15. I switch to the Pro ET Street radial to enter events where Dot tires are required, My car weighs around 3500 pounds with driver and has run 9.8s ..1.42 60 ft times. We dialed it back to 10.1.We have Caltracs with Viking Rear shocks set a C 14 R 8. I have some traction problems with the Single adjustable shocks, but after switching to the dual adjustable no more problems. On my car I saw no difference between the Pro Bracket Radial and the Pro Et Street radials faster cars might, but I didn’t. Love them just bought a new set, it’s a Street/ Strip car with a 512, foot braking. It’s a 69 Dart.
Re: Anyone here running MT Pro Bracket Radials ? [Re: tex013] #2659177
05/25/19 09:12 PM
05/25/19 09:12 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
I'm running these on my wagon around 4000-4100lbs. Runs a best of 7.02 in the 1/8. I found very consistent 60' times once I got used to what they liked for a burn out. For my very short, little smoke worked best. My 60's are usually 1.53 with these.
Oh my wagon uses 8" rims and 20 psi wks best.
Ok
Re: Anyone here running MT Pro Bracket Radials ? [Re: cudatom] #2659234
05/26/19 01:15 AM
05/26/19 01:15 AM
Sydney,Australia
Sydney,Australia
Wowser , this is an old thread
I did go the PBR . 28x10.5
Though now have the 29.5 x10.5
Only drawback is i have to deflate them to fit both in the boot with all my other stuff . Never needed to with the 28s
Tex
New best MPH 130.32
