help me build a 440 for a c body
#1947377
11/08/15 03:44 AM
11/08/15 03:44 AM
Posts: 35 Livonia,MI
1968fury
Livonia,MI
I'm finally getting around to build a 440 for a 68 fury1 2door sedan (my first car had it 20 years). Looking for advice so I don't build a turd. I bought a bunch of stuff from someone that drag raced in the early to mid 90's and hoping to use some of the stuff to build a budget 440 to run mid 12ish. My plan is to build a 10:1 440,906 heads that have been bowl ported,crane adustable 1.5 rockers,Mopar 528 solid cam,Mallory unilite,performer rpm or weiand sigle plane intake.850 Holley carb. 4 speed and 323 gear(car is a 3speed on the tree).
I have every thing but the cam and performer rpm. Not sure about what cam to buy I would like to use a solid lifter. Or if I should buy headers.also not sure if the heads are going to cost me more than its worth to use them. I did get a 590 and 620? Lift Mopar cams with the stuff I bought but they seem to much. Thanks
71 scamp 340 509 cam 456 gear,68 fury1 318 3spd on the tree,50 merc flathead 3x2 3spd w/overdrive
Re: help me build a 440 for a c body
[Re: 1968fury]
#1947431
11/08/15 11:12 AM
11/08/15 11:12 AM
Posts: 4,321 Prospect, PA
BSB67
Prospect, PA
Is it a drag race car? What is the goal for the car? Do you have pistons yet?
I would focus on getting the right piston head combination, and it probably would not include the 906 head given a choice. A bowl ported 906 will probably flow 235-240 cfm, and will be a non-quench 9 or 9.5:1 if you want to run pump gas. You can still get there with the 906, but you'll have to make it up else where in the combo.
A 10 or 10.5:1 CR aftermarket head with quench and better flow numbers will make easier, but may cost more depending on the current status of your head/piston situation.
[Re: 1968fury]
#1947499
11/08/15 01:47 PM
11/08/15 01:47 PM
Posts: 671 Wisconsin USA
Bill MeLater
Wisconsin USA
I'm finally getting around to build a 440 for a 68 fury1 2door sedan (my first car had it 20 years). Looking for advice so I do build a turd. I bought a bunch of stuff from someone that drag raced in the early to mid 90's and hoping to use some of the stuff to build a budget 440 to run mid 12ish. My plan is to build a 10:1 440,906 heads that have been bowl ported,crane adustable 1.5 rockers,Mopar 528 solid cam,Mallory unilite,performer rpm or weiand sigle plane intake.850 Holley carb. 4 speed and 323 gear(car is a 3speed on the tree).
I have every thing but the cam and performer rpm. Not sure about what cam to buy I would like to use a solid lifter. Or if I should buy headers.also not sure if the heads are going to cost me more than its worth to use them. I did get a 590 and 620? Lift Mopar cams with the stuff I bought but they seem to much. Thanks Are you absolutely certain you want to build a turd?
[Re: Bill MeLater]
#1947512
11/08/15 02:24 PM
11/08/15 02:24 PM
1968fury
Livonia,MI
Ha I missed that,fixed it.
The car will be a street car that goes to the track 3-4 times a year. I have 2 assembled short blocks both have trw pistons one has flat tops and one has domed pistons
[Re: 1968fury]
#1947588
11/08/15 04:23 PM
11/08/15 04:23 PM
Posts: 43,311 Bend,OR USA
Cab_Burge
Sell both those short blocks and build a 400 block stroker motor, 505(4.250 stroke) to 518 C.I.(4.300 stroke) AKA aside, those cars are heavy, to make your power goals achievable you need C.I., the longer stroke will increase the C.I. and the torque dramatically You need torque to start to move the mass The last pump gas 440 motor I dymo tuned and built was a 464 C.I. motor with a offset ground 440 crank increased the stroke to 3.91, made 430 HP (.926 HP per C.I.)and 470 Ft lbs torque with iron heads( 9.6 to 1 comp. ratio) with a very mild street hydrauilc cam ground on a 112 LSA for power brakes, the same parts, compression ratio, camshaft, cylinder heads and intake and carb. in a 4.250 stroke motor would have made similar HP per C.I. and more Ft lbs per C.I. IE 505 C.I. X .926 = 467.9 HP. Put a better set of new aluminum heads on that short block and bump up the C.I. ratio to 10.25 to to 10.75 to 1 and the HP per C.I. will increase to around 1.10 HP per C.I. or more depending on the heads and camshaft and so on The major bad thing about making more power per C.I. is the increased cost of the better parts I love 4 speed cars, I hate working on the driveline parts though IHTHs
[Re: lewtot184]
#1947683
11/08/15 08:34 PM
11/08/15 08:34 PM
1968fury
Livonia,MI
a kb184 piston with an open chamber head will make more power than a 10:1 flat top open chamber head combo. flat tops and open chamber heads aren't ideal with today's gas. I just looked at my pistons. They are trw L2295f they look like the kb184 pistons. I'm not sure if they are similar or not. I'm trying to do this on a tight budget so I would like to use as much of this stuff I have as possible. I'm going to leave the bottle cap hubcaps,radio delete and bench seat on the car. I would like it to look factory made... I have 2 other motors I'm trying to put together over the winter so money is tight. I figure I can always change the gear to a 391 in the next year or so.
[Re: 1968fury]
#1947942
11/09/15 06:37 AM
11/09/15 06:37 AM
Posts: 214 Hamburg / Germany
Den300
Hamburg / Germany
mine is a 440 + 0.30 with the 2295 pistons. 10.78:1 compression. ported edelbrock heads, ch-28 dual quad intake and to 600cfm ede carbs. 1 3/7 to 3" exhaust system, 3.91 rear axle and a solid flat tapped cam from scott brown. roughly .530 lift on both side and 236/246 (265/278 adv.) duration. car runs 12.8 at the quarter mile and can go 300miles on a road trip without a problem. rockers are the black indy ones. switch now to a solid roller nd bigger headers, but that was a good powerful engine. made 440rwhp@6000rpm at the dyno.
Hamburg/Germany
69 Chrysler 300 446cui Dual Quad 12.64 @ 110.7
[Re: 1968fury]
#1948014
11/09/15 12:29 PM
11/09/15 12:29 PM
Posts: 3,254 Md.
carnut68
Md.
If the car is going to see a lot of street time I wouldn't use the 590 cam. It has no street manners,idles around 12-1500. The 557 would be better.IMO. You said tight budget get a valve job, check the valve springs replace if needed. Run those heads, use what you have. Headers if you can afford them. If you are startin from scratch things to consider. Ignition system, cooling system, a good drive line. Remember the key words "on a budget"
America First!
[Re: Bill MeLater]
#1948427
11/09/15 11:41 PM
11/09/15 11:41 PM
1968fury
Livonia,MI
Can someone please tell me why a muscle car needs manners? Is that not irony at its finest? Build a Bently, they have manners. The ones with no manners are the most fun. I just figured it's a big heavy car, and with stock valve heads I'd be better off with a dual plane and more of a low/mid range cam. I'm not sure whether to run the 528cam or a voodoo solid or a Hughes solid. If I had better heads a gear and headers I'd probably run the 590
[Re: 1968fury]
#1948461
11/10/15 12:20 AM
11/10/15 12:20 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
It's a C body - not a muscle car. It's a heavy weight that has to be pushed forward. While I agree with the "use what you can" the question becaomes can what you have be used to get the result? I think a C body, manual trans, with 3.23s will need a bit more head and cam to make it into the 12s. However, that could be made up by going bigger on the stroke. I'd sell everything for the shortblocks but one machined block. Use the proceeds to buy a stroker kit, and a set of Stealth heads. The .528 cam can make great torque with good heads. That should be able to do what you want, right up until it rips the driveshaft out or shears the pinion gear...lol.
[Re: 1968fury]
#1948804
11/10/15 03:57 PM
11/10/15 03:57 PM
1968fury
Livonia,MI
Thanks for all the advice. Dropped the heads off at the machine shop for a refreshing. He is going to call me if they need I ton of work.
I noticed one short block has a 8 bolt crank so I have to figure out what that's all about.
[Re: 1968fury]
#1949069
11/10/15 10:48 PM
11/10/15 10:48 PM
moper
Columbia, CT
Could be an industrial crank? I think some of those had the 8 bolt pattern. No big deal - just need to make sure the right flexplate is used and that the crank hub size and reister is the same. My 300 is no muscle car. My Imperial isn't either.
[Re: Bill MeLater]
#1949150
11/11/15 12:44 AM
11/11/15 12:44 AM
1968fury
Livonia,MI
I believe you were told you do not own a muscle car OK. Well they made big block 4 spd cars from the factory. It's really not much bigger than a b body. I don't think 12 second is that much to ask. If I wanted to go fast I'd build an a body. I'm not saying its a muscle car but it would be a lot more fun to drive with a 440 4 spd than a 318 3speed.
[Re: 1968fury]
#1949196
11/11/15 02:14 AM
11/11/15 02:14 AM
Posts: 10,234 Someplace you aren't
SomeCarGuy
Who cares if it is a "muscle car?" What does that have to do with the price of eggs in Amsterdam?.
I want my fair share
[Re: SomeCarGuy]
#1949202
11/11/15 02:29 AM
11/11/15 02:29 AM
1968fury
Livonia,MI
Who cares if it is a "muscle car?" What does that have to do with the price of eggs in Amsterdam?. Ha exactly
[Re: 1968fury]
#1949250
11/11/15 08:10 AM
11/11/15 08:10 AM
Posts: 234 Brisvegas, Australia
Alchemi
Hey its muscle enough - put it side by side with a '68 RR and play spot the difference.... Base model one aint much difference in weight to a "B" either - most of the size difference is air If anything its superior, there is a butt tonne of chassis connecting the upper A-Arms to the rest of the car No its not technically a muscle car, just think of it as having a whole gym Yes I own one too... lols
[Re: 1968fury]
#1949270
11/11/15 10:24 AM
11/11/15 10:24 AM
Posts: 10,020 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I like your cam choice, the 528, but the gears need to be 3.55 or 3.73 for some compromise in getting this car to move. I run 3.55s on the street with a 27.3 inch tall rear tire, and I go to cruise nights sixty miles away, no problem even on the freeway. On the heads, I would do my best to budget for aluminum heads. The 906 castings have weak points, and having cracked a set with a lot of $$ in them , I don't like to see guys putting money into those castings. By building it right with good quench, .050 or closer on piston to head clearance and lower drag 1/16 rings on a flat top piston, you will make a good amount more torque and you need all you can get with what you want to do here.
[Re: 1968fury]
#1951843
11/15/15 08:09 PM
11/15/15 08:09 PM
1968fury
Livonia,MI
[Re: 1968fury]
#1952195
11/16/15 09:43 AM
11/16/15 09:43 AM
Posts: 2,933 Finalnd, Perkele
jyrki
Finalnd, Perkele
Our '67 VIP run 10.6's naturally aspirated. Sure it had 4.10 gear, but the tires were 32", and the trans was an automatic, 1.8 first gear. The manual will propably be a challenge with the long gear ratio. Other than that, it shouldn't be very hard. Our old '67 III run 13.8/103 with a smog short block (not much CR), slightly cleaned open chamber heads, MP 280 hydraulic cam, 1 3/4" headers, Torker 2 intake, 3310 Holley, stock torque convertere and 3.23 gears.
Plynouth VIP '67 TT IC EFI
[Re: Bill MeLater]
#1953642
11/18/15 12:55 PM
11/18/15 12:55 PM
Posts: 3,923 Richmond, Indiana
19swinger70
Richmond, Indiana
I believe you were told you do not own a muscle car What the hell is your problem?
1970 340 swinger. sublime 1967 barracuda fastback BB 55 Plymouth Project
[Re: jyrki]
#1953874
11/18/15 07:53 PM
11/18/15 07:53 PM
1968fury
Livonia,MI
Our '67 VIP run 10.6's naturally aspirated. Sure it had 4.10 gear, but the tires were 32", and the trans was an automatic, 1.8 first gear. The manual will propably be a challenge with the long gear ratio. Other than that, it shouldn't be very hard. Our old '67 III run 13.8/103 with a smog short block (not much CR), slightly cleaned open chamber heads, MP 280 hydraulic cam, 1 3/4" headers, Torker 2 intake, 3310 Holley, stock torque convertere and 3.23 gears. Nice do you have any pics of the cars.
