help me build a 440 for a c body #1947377
11/08/15 03:44 AM
11/08/15 03:44 AM
Livonia,MI
1968fury Offline OP
1968fury  Offline OP
Livonia,MI
I'm finally getting around to build a 440 for a 68 fury1 2door sedan (my first car had it 20 years). Looking for advice so I don't build a turd. I bought a bunch of stuff from someone that drag raced in the early to mid 90's and hoping to use some of the stuff to build a budget 440 to run mid 12ish. My plan is to build a 10:1 440,906 heads that have been bowl ported,crane adustable 1.5 rockers,Mopar 528 solid cam,Mallory unilite,performer rpm or weiand sigle plane intake.850 Holley carb. 4 speed and 323 gear(car is a 3speed on the tree).
I have every thing but the cam and performer rpm. Not sure about what cam to buy I would like to use a solid lifter. Or if I should buy headers.also not sure if the heads are going to cost me more than its worth to use them. I did get a 590 and 620? Lift Mopar cams with the stuff I bought but they seem to much. Thanks
71 scamp 340 509 cam 456 gear,68 fury1 318 3spd on the tree,50 merc flathead 3x2 3spd w/overdrive
Re: help me build a 440 for a c body [Re: 1968fury] #1947431
11/08/15 11:12 AM
11/08/15 11:12 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Is it a drag race car? What is the goal for the car? Do you have pistons yet?
I would focus on getting the right piston head combination, and it probably would not include the 906 head given a choice. A bowl ported 906 will probably flow 235-240 cfm, and will be a non-quench 9 or 9.5:1 if you want to run pump gas. You can still get there with the 906, but you'll have to make it up else where in the combo.
A 10 or 10.5:1 CR aftermarket head with quench and better flow numbers will make easier, but may cost more depending on the current status of your head/piston situation.
Re: help me build a 440 for a c body [Re: 1968fury] #1947499
11/08/15 01:47 PM
11/08/15 01:47 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
Originally Posted By 1968fury
I'm finally getting around to build a 440 for a 68 fury1 2door sedan (my first car had it 20 years). Looking for advice so I do build a turd. I bought a bunch of stuff from someone that drag raced in the early to mid 90's and hoping to use some of the stuff to build a budget 440 to run mid 12ish. My plan is to build a 10:1 440,906 heads that have been bowl ported,crane adustable 1.5 rockers,Mopar 528 solid cam,Mallory unilite,performer rpm or weiand sigle plane intake.850 Holley carb. 4 speed and 323 gear(car is a 3speed on the tree).
Are you absolutely certain you want to build a turd?
Re: help me build a 440 for a c body [Re: Bill MeLater] #1947512
11/08/15 02:24 PM
11/08/15 02:24 PM
Livonia,MI
1968fury Offline OP
1968fury  Offline OP
Livonia,MI
Ha I missed that,fixed it.
The car will be a street car that goes to the track 3-4 times a year. I have 2 assembled short blocks both have trw pistons one has flat tops and one has domed pistons
Re: help me build a 440 for a c body [Re: 1968fury] #1947518
11/08/15 02:45 PM
11/08/15 02:45 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
Stranger builds have been done, but a stick w/3.23s + HEAVY car isn't going to be easy on driveline parts. twocents
72 Plymouth Roadrunner 11.08@123.25
Re: help me build a 440 for a c body [Re: 1968fury] #1947570
11/08/15 04:01 PM
11/08/15 04:01 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
a kb184 piston with an open chamber head will make more power than a 10:1 flat top open chamber head combo. flat tops and open chamber heads aren't ideal with today's gas.
Re: help me build a 440 for a c body [Re: 1968fury] #1947588
11/08/15 04:23 PM
11/08/15 04:23 PM
Sell both those short blocks and build a 400 block stroker motor, 505(4.250 stroke) to 518 C.I.(4.300 stroke) thumbs twocents AKA aside, those cars are heavy, to make your power goals achievable you need C.I., the longer stroke will increase the C.I. and the torque dramatically scope You need torque to start to move the mass work shruggy The last pump gas 440 motor I dymo tuned and built was a 464 C.I. motor with a offset ground 440 crank increased the stroke to 3.91, made 430 HP (.926 HP per C.I.)and 470 Ft lbs torque with iron heads( 9.6 to 1 comp. ratio) with a very mild street hydrauilc cam ground on a 112 LSA for power brakes, the same parts, compression ratio, camshaft, cylinder heads and intake and carb. in a 4.250 stroke motor would have made similar HP per C.I. and more Ft lbs per C.I. thumbs IE 505 C.I. X .926 = 467.9 HP. Put a better set of new aluminum heads on that short block and bump up the C.I. ratio to 10.25 to to 10.75 to 1 and the HP per C.I. will increase to around 1.10 HP per C.I. or more depending on the heads and camshaft and so on thumbs scope The major bad thing about making more power per C.I. is the increased cost of the better parts shruggy I love 4 speed cars, I hate working on the driveline parts though realcrazyIHTHs
Re: help me build a 440 for a c body [Re: lewtot184] #1947683
11/08/15 08:34 PM
11/08/15 08:34 PM
Livonia,MI
1968fury Offline OP
1968fury  Offline OP
Livonia,MI
I just looked at my pistons. They are trw L2295f they look like the kb184 pistons. I'm not sure if they are similar or not. I'm trying to do this on a tight budget so I would like to use as much of this stuff I have as possible.
I'm going to leave the bottle cap hubcaps,radio delete and bench seat on the car. I would like it to look factory made...
I have 2 other motors I'm trying to put together over the winter so money is tight. I figure I can always change the gear to a 391 in the next year or so.
Re: help me build a 440 for a c body [Re: 1968fury] #1947795
11/08/15 11:50 PM
11/08/15 11:50 PM
Wisconsin USA
Wisconsin USA
Build it with the 2295's and the 590 cam. Use the heaviest flywheel/ clutch (143 tooth, 11") you can find. Your tires will save your driveline . You'll love it for not much $ When you get some dough, swap gears for more fun...
Re: help me build a 440 for a c body [Re: 1968fury] #1947942
11/09/15 06:37 AM
11/09/15 06:37 AM
Hamburg / Germany
Den300 Offline
Den300  Offline
Hamburg / Germany
mine is a 440 + 0.30 with the 2295 pistons. 10.78:1 compression.
ported edelbrock heads, ch-28 dual quad intake and to 600cfm ede carbs.
1 3/7 to 3" exhaust system, 3.91 rear axle and a solid flat tapped cam from
scott brown. roughly .530 lift on both side and 236/246 (265/278 adv.) duration.
car runs 12.8 at the quarter mile and can go 300miles on a road trip without a problem.
rockers are the black indy ones. switch now to a solid roller nd bigger headers,
but that was a good powerful engine. made 440rwhp@6000rpm at the dyno.
Hamburg/Germany
69 Chrysler 300
446cui Dual Quad
12.64 @ 110.7
Re: help me build a 440 for a c body [Re: 1968fury] #1948014
11/09/15 12:29 PM
11/09/15 12:29 PM
Md.
carnut68 Offline
carnut68  Offline
Md.
If the car is going to see a lot of street time I wouldn't use the 590 cam. It has no street manners,idles around 12-1500. The 557 would be better.IMO. You said tight budget get a valve job, check the valve springs replace if needed. Run those heads, use what you have. Headers if you can afford them. If you are startin from scratch things to consider. Ignition system, cooling system, a good drive line. Remember the key words "on a budget"
America First!
Re: help me build a 440 for a c body [Re: 1968fury] #1948197
11/09/15 06:41 PM
11/09/15 06:41 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I'd find a used edelbrock ch4b intake and run the mp528 cam. Would make for a great street car.
Re: help me build a 440 for a c body [Re: DaytonaTurbo] #1948413
11/09/15 11:17 PM
11/09/15 11:17 PM
Wisconsin USA
Wisconsin USA
Can someone please tell me why a muscle car needs manners? Is that not irony at its finest? Build a Bently, they have manners.
Re: help me build a 440 for a c body [Re: Bill MeLater] #1948427
11/09/15 11:41 PM
11/09/15 11:41 PM
Livonia,MI
1968fury Offline OP
1968fury  Offline OP
Livonia,MI
The ones with no manners are the most fun. I just figured it's a big heavy car, and with stock valve heads I'd be better off with a dual plane and more of a low/mid range cam.
I'm not sure whether to run the 528cam or a voodoo solid or a Hughes solid.
If I had better heads a gear and headers I'd probably run the 590
Re: help me build a 440 for a c body [Re: 1968fury] #1948461
11/10/15 12:20 AM
11/10/15 12:20 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
It's a C body - not a muscle car. It's a heavy weight that has to be pushed forward. While I agree with the "use what you can" the question becaomes can what you have be used to get the result? I think a C body, manual trans, with 3.23s will need a bit more head and cam to make it into the 12s. However, that could be made up by going bigger on the stroke. I'd sell everything for the shortblocks but one machined block. Use the proceeds to buy a stroker kit, and a set of Stealth heads. The .528 cam can make great torque with good heads. That should be able to do what you want, right up until it rips the driveshaft out or shears the pinion gear...lol.
Re: help me build a 440 for a c body [Re: 1968fury] #1948804
11/10/15 03:57 PM
11/10/15 03:57 PM
Livonia,MI
1968fury Offline OP
1968fury  Offline OP
Livonia,MI
Thanks for all the advice. Dropped the heads off at the machine shop for a refreshing. He is going to call me if they need I ton of work.
I noticed one short block has a 8 bolt crank so I have to figure out what that's all about.
Re: help me build a 440 for a c body [Re: 1968fury] #1948820
11/10/15 04:17 PM
11/10/15 04:17 PM
dogdays Offline
dogdays  Offline
Make sure all the 8 bolt holes are threaded.
R.
Re: help me build a 440 for a c body [Re: 1968fury] #1949053
11/10/15 10:29 PM
11/10/15 10:29 PM
Wisconsin USA
Wisconsin USA
I believe you were told you do not own a muscle car
Re: help me build a 440 for a c body [Re: 1968fury] #1949069
11/10/15 10:48 PM
11/10/15 10:48 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Could be an industrial crank? I think some of those had the 8 bolt pattern. No big deal - just need to make sure the right flexplate is used and that the crank hub size and reister is the same.
My 300 is no muscle car. My Imperial isn't either.
Re: help me build a 440 for a c body [Re: Bill MeLater] #1949150
11/11/15 12:44 AM
11/11/15 12:44 AM
Livonia,MI
1968fury Offline OP
1968fury  Offline OP
Livonia,MI
OK. Well they made big block 4 spd cars from the factory. It's really not much bigger than a b body. I don't think 12 second is that much to ask. If I wanted to go fast I'd build an a body. I'm not saying its a muscle car but it would be a lot more fun to drive with a 440 4 spd than a 318 3speed.
