I need a pump cover that provides outlets for remote filter to run through a motor plate. The 440 Source pump cover I was hoping to use is too wide. I need one that is approximately flush with the pump. Otherwise I will need to further modify the plate, which I am not anxious to do. Could someone please get me a picture of the Milodon cover 21235 mounted on a Melling HV pump? Much appreciated.
This space not for rent.
