The inexpensive PT-8519 should work if compression is under 11:1.
I think the bore size is close to 4.50".
![scope scope](/ubbthreads/images/graemlins/custom/scope.gif)
I use those all the time on aluminum headed motors
Ok. Here is a little more info on the motor.
400 Block bored 60 over.
4.15 Stroke. I believe this all comes out to 505ci.
When we ordered the pistons I had a choice of 10:1 or 12:1. I went with the 12:1 hoping that my cam selection would help drop some of the cyl pressure.
Trick Flow 240 aluminum heads.
I'm looking to use a solid flat tappet cam: comp cam 23-232-4 which has int duraration of 244 @ .050.
The car will be driven to shows and raced with the car club a few times a year just for fun.
I know this is a lot of information just for head gaskets. I don't mind buying the more expensive gaskets if that is what I need to do.
