Re: Rocker Arm Failure: Was I asking to much? [Re: MadMopars] #1946451
11/06/15 05:50 PM
11/06/15 05:50 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Boffin Emeritus
Re: Rocker Arm Failure: Was I asking to much? [Re: johnnycuda] #1946456
11/06/15 06:02 PM
11/06/15 06:02 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Originally Posted By johnnycuda
Hey Trent, I just installed a set of Comp Cams Ultra Pro Magnums,#1621-16, they're a moly steel, were quieter going down the road than my aluminum set, my spring pressure around 220 on the seat and 430 open if I remeember right, .600 lift solid roller, no problems with them on Drag Weekend or mdriving around here before hand.
Another good option and I ran those for years w/a solid flat tappet cam before steppin up to a solid roller myself BUT, was told by Comp. those would be marginal at my 580+ open pressures I now run.......
Re: Rocker Arm Failure: Was I asking to much? [Re: MadMopars] #1946463
11/06/15 06:07 PM
11/06/15 06:07 PM
lancaster,california
johnnycuda Offline
johnnycuda  Offline
Hey Dom, these are actually a new set, much stronger than the older set, can handle much more spring pressure, I talked to my friend who works tech there before ordering them, so hopefully all goes well.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT!
1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air,
New daily driver-2003 Ram 2500 Cummins 5.9
'69 Valiant 2-dr, sleeper!
New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
Re: Rocker Arm Failure: Was I asking to much? [Re: johnnycuda] #1946512
11/06/15 07:21 PM
11/06/15 07:21 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
""Comp Cams Ultra Pro Magnums,#1621-16""
I just emailed CC about two weeks ago about these rockers. Their reply was 500lbs open force is their spec.
Re: Rocker Arm Failure: Was I asking to much? [Re: johnnycuda] #1946526
11/06/15 07:51 PM
11/06/15 07:51 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Good to know. Can they handle 600+ open pressures cos I`m lookin for new bushed rockers w/out going to exotic stuff that I don`t need. thumbs
Re: Rocker Arm Failure: Was I asking to much? [Re: MadMopars] #1946546
11/06/15 08:51 PM
11/06/15 08:51 PM
Locomotion Offline
Locomotion  Offline
If I understood correctly, you swapped from 1.5 to 1.6? If so, you gained almost .050" in lift. Was guide-to-retainer clearance checked? (Unless I missed it.) But higher ratio rockers do put more stress on things because of faster opening and closing rates. More spring pressure is usually needed, but you seem to have a good bit.
Re: Rocker Arm Failure: Was I asking to much? [Re: MadMopars] #1946561
11/06/15 09:24 PM
11/06/15 09:24 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
It would seem to me that the open pressure is a moot point when it comes top the valve. When the valve is open, its just hanging there and the pressure is on the pushrod and valvetrain. When its CLOSED, that's the pressure the valve sees against the seat.
Re: Rocker Arm Failure: Was I asking to much? [Re: Thumperdart] #1946565
11/06/15 09:31 PM
11/06/15 09:31 PM
johnnycuda Offline
johnnycuda  Offline
Hey Dom, I know they were ok for more than what I am running, were checked higher than what they are quoting to be safe.
Re: Rocker Arm Failure: Was I asking to much? [Re: Locomotion] #1946702
11/07/15 12:30 AM
11/07/15 12:30 AM
Tucson AZ,
MadMopars Offline OP
Tucson AZ,
I switched from 1.5 rockers to 1.6 to account for net lift loss after correcting the valvetrain geometry. Originally I had .525 net lift with 1.5 rockers and 90 degrees at full lift. After switching to 90 degrees at mid lift my net lift was .500. When I put the 1.6 rockers on my net lift is .540.
Coil bind for these springs occurs @ 1.16 according to the spec sheet.
Given that the valves actually rotated for what I believe is the first time, I'm starting to think there were some harmonics occurring.
Obviously it's time to dump the rockers but I'm thinking some different valve springs may be in order as well.
Without getting stones thrown at me, anyone ever have luck running the steel PRW rockers?
[img]https://s9.postimg.cc/6fbjxzfvv/48-2016-_Drag-_Weekend-_Best-_Burnouts-lpr.jpg[/img]
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
64 F100 *383*4 SPEED*9"*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
Re: Rocker Arm Failure: Was I asking to much? [Re: polyspheric] #1946740
11/07/15 01:36 AM
11/07/15 01:36 AM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
Originally Posted By polyspheric
CAT (and many other questionable manufacturers) have long since learned that for most speed equipment customers, external finish is the only thing that matters ("look, it's shinyyyy!"). One year less in R&D is easily made up for by an extra hour on the buffing wheel.
The 1.6 HS rockers in the 540 are probably the shiniest and prettiest rockers I have seen. Are they junk?
Re: Rocker Arm Failure: Was I asking to much? [Re: MadMopars] #1946904
11/07/15 01:44 PM
11/07/15 01:44 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Boffin Emeritus
Re: Rocker Arm Failure: Was I asking to much? [Re: MadMopars] #1946965
11/07/15 03:06 PM
11/07/15 03:06 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
The problem could have simply been too much lash. There is a difference in the lash being at .025 or so in a 180 degree motor for a few seconds on the race track........and going down the road at that number at 3000rpms for sustained periods, at high engine temps.
Re: Rocker Arm Failure: Was I asking to much? [Re: MadMopars] #1946978
11/07/15 03:31 PM
11/07/15 03:31 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I had some CAT stainless steel body rockers, and the roller tips started wearing down, they must have been really soft steel. I just replaced them with Harlan Sharpe rockers, no problems with those.
Re: Rocker Arm Failure: Was I asking to much? [Re: Airwoofer] #1946982
11/07/15 03:39 PM
11/07/15 03:39 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Nope..............like everything else, they have their place and mine are 8+ years old street/strip but low 210-235 seat and 480-500 open.......
Re: Rocker Arm Failure: Was I asking to much? [Re: MadMopars] #1947674
11/08/15 08:16 PM
11/08/15 08:16 PM
Washington
madscientist Offline
Washington
So how did you correct the geometry when you changed rockers?
I seriously doubt that cam hurt anything. Your paultry spring pressures (by todays standard) shouldn't hurt anything either.
Re: Rocker Arm Failure: Was I asking to much? [Re: MadMopars] #1947757
11/08/15 10:35 PM
11/08/15 10:35 PM
Texas
ChevyTS Offline
ChevyTS  Offline
Texas
Are you lashing the valves one cylinder at a time or are you using the crankshaft degrees?
T & K Performance
Re: Rocker Arm Failure: Was I asking to much? [Re: MadMopars] #1947790
11/08/15 11:37 PM
11/08/15 11:37 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
As said they are junk.
C.A.T NO, Needle bearing rockers NO.
Yep Crane Gold or even better Hughes.
1963 Plymouth Max Wedge
1971 Barracuda
