Re: LS Springs
[Re: Max Weg]
#1946087
11/06/15 02:21 AM
11/06/15 02:21 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
The above springs listed by Alex are good for the older 5.7 and 6.1 heads. There are better options for eagles and apache heads
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
Re: LS Springs
[Re: Max Weg]
#1946217
11/06/15 12:36 PM
11/06/15 12:36 PM
sixpackgut
Charleston
i am currently working on the older heads but I have som appache and I am looking for some eagles. Any info would be greatly appreciated.
Max Weg this is what BES runs on the newer heads and I bought this kit. it comes with a shim pack. springs and retainers. I looked to see if you can piece part cheaper but I couldn't do it. You could probably get away with not buying the retainers which are stupid money. part numbers are there http://www.highhorseperformance.com/PSI_Valve_Spring_Manley_Titanium_Retainer_p/1515springkit2.htm
Re: LS Springs
[Re: Max Weg]
#1947262
11/07/15 11:33 PM
11/07/15 11:33 PM
Posts: 723 Houston Tx
Uhcoog1
Houston Tx
1218x on my old style 5.7 heads.
Alex used to sell FRI and GTP cylinder heads. He knows his stuff.
-'02 Dodge Viper Ex-World Challenge racecar -'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: LS Springs
[Re: Max Weg]
#1947496
11/08/15 01:39 PM
11/08/15 01:39 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I'm using Manley Nexteks.
Mopar to the bone!!!
Re: LS Springs
[Re: Max Weg]
#2008384
02/09/16 02:29 AM
02/09/16 02:29 AM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
GM performance has factory springs good to .570 lift and they are only around $60 shipped for a set of 16. I think they are ls9 or ls6 factory springs... just installed a set in my ls1.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
