Re: Rocker Arm Failure: Was I asking to much?
[Re: johnnycuda]
#1946456
11/06/15 06:02 PM
11/06/15 06:02 PM
Thumperdart
State of confusion
Hey Trent, I just installed a set of Comp Cams Ultra Pro Magnums,#1621-16, they're a moly steel, were quieter going down the road than my aluminum set, my spring pressure around 220 on the seat and 430 open if I remeember right, .600 lift solid roller, no problems with them on Drag Weekend or mdriving around here before hand. Another good option and I ran those for years w/a solid flat tappet cam before steppin up to a solid roller myself BUT, was told by Comp. those would be marginal at my 580+ open pressures I now run.......
[Re: MadMopars]
#1946463
11/06/15 06:07 PM
11/06/15 06:07 PM
Posts: 861 lancaster,california
johnnycuda
Hey Dom, these are actually a new set, much stronger than the older set, can handle much more spring pressure, I talked to my friend who works tech there before ordering them, so hopefully all goes well.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
[Re: johnnycuda]
#1946512
11/06/15 07:21 PM
11/06/15 07:21 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
""Comp Cams Ultra Pro Magnums,#1621-16""
I just emailed CC about two weeks ago about these rockers. Their reply was 500lbs open force is their spec.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: johnnycuda]
#1946526
11/06/15 07:51 PM
11/06/15 07:51 PM
Thumperdart
State of confusion
Hey Dom, these are actually a new set, much stronger than the older set, can handle much more spring pressure, I talked to my friend who works tech there before ordering them, so hopefully all goes well. Good to know. Can they handle 600+ open pressures cos I`m lookin for new bushed rockers w/out going to exotic stuff that I don`t need.
[Re: MadMopars]
#1946561
11/06/15 09:24 PM
11/06/15 09:24 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
It would seem to me that the open pressure is a moot point when it comes top the valve. When the valve is open, its just hanging there and the pressure is on the pushrod and valvetrain. When its CLOSED, that's the pressure the valve sees against the seat.
[Re: Thumperdart]
#1946565
11/06/15 09:31 PM
11/06/15 09:31 PM
johnnycuda
Hey Dom, I know they were ok for more than what I am running, were checked higher than what they are quoting to be safe. Hey Dom, these are actually a new set, much stronger than the older set, can handle much more spring pressure, I talked to my friend who works tech there before ordering them, so hopefully all goes well. Good to know. Can they handle 600+ open pressures cos I`m lookin for new bushed rockers w/out going to exotic stuff that I don`t need.
[Re: Locomotion]
#1946702
11/07/15 12:30 AM
11/07/15 12:30 AM
Posts: 1,296 Tucson AZ,
MadMopars
Tucson AZ,
If I understood correctly, you swapped from 1.5 to 1.6? If so, you gained almost .050" in lift. Was guide-to-retainer clearance checked? (Unless I missed it.) But higher ratio rockers do put more stress on things because of faster opening and closing rates. More spring pressure is usually needed, but you seem to have a good bit. I switched from 1.5 rockers to 1.6 to account for net lift loss after correcting the valvetrain geometry. Originally I had .525 net lift with 1.5 rockers and 90 degrees at full lift. After switching to 90 degrees at mid lift my net lift was .500. When I put the 1.6 rockers on my net lift is .540. Coil bind for these springs occurs @ 1.16 according to the spec sheet. Given that the valves actually rotated for what I believe is the first time, I'm starting to think there were some harmonics occurring. Obviously it's time to dump the rockers but I'm thinking some different valve springs may be in order as well. Without getting stones thrown at me, anyone ever have luck running the steel PRW rockers?
[Re: polyspheric]
#1946740
11/07/15 01:36 AM
11/07/15 01:36 AM
Posts: 655 Huntsville, AL
Airwoofer
Huntsville, AL
CAT (and many other questionable manufacturers) have long since learned that for most speed equipment customers, external finish is the only thing that matters ("look, it's shinyyyy!"). One year less in R&D is easily made up for by an extra hour on the buffing wheel.
The 1.6 HS rockers in the 540 are probably the shiniest and prettiest rockers I have seen. Are they junk?
[Re: Airwoofer]
#1946982
11/07/15 03:39 PM
11/07/15 03:39 PM
Thumperdart
State of confusion
The 1.6 HS rockers in the 540 are probably the shiniest and prettiest rockers I have seen. Are they junk? Nope..............like everything else, they have their place and mine are 8+ years old street/strip but low 210-235 seat and 480-500 open.......
[Re: MadMopars]
#1947674
11/08/15 08:16 PM
11/08/15 08:16 PM
Posts: 4,457 Washington
madscientist
Washington
So how did you correct the geometry when you changed rockers?
I seriously doubt that cam hurt anything. Your paultry spring pressures (by todays standard) shouldn't hurt anything either.
[Re: MadMopars]
#1947757
11/08/15 10:35 PM
11/08/15 10:35 PM
Posts: 576 Texas
ChevyTS
Texas
Are you lashing the valves one cylinder at a time or are you using the crankshaft degrees?
T & K Performance
[Re: MadMopars]
#1947790
11/08/15 11:37 PM
11/08/15 11:37 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
As said they are junk. C.A.T NO, Needle bearing rockers NO.
Yep Crane Gold or even better Hughes.
1963 Plymouth Max Wedge 1971 Barracuda
